rjwein
(Reese)
May 15, 2024, 3:09pm
1
Hi all,
I’m having trouble importing pyrevit inside of the revit python shell. I get the following errors:
As per this forum post , I’m attempting to add in the path to pyrevit library:
Any hint as to what might be going on would be appreciated! Thanks in advance.
Some other potentially useful details:
Utilizing pyRevit tools from the toolbar seems to work just fine
In Revit 2021
jpitts
(JP)
May 16, 2024, 2:58am
2
Ironpython 2.7.7 means you are using old pyrevit release. Have you tried with the latest release with the 2711 engine?
Jean-Marc
(Jean-Marc Couffin)
May 16, 2024, 6:08am
3
And an old version of RPS which necessarily doesn’t help
rjwein
(Reese)
May 16, 2024, 1:10pm
4
Since I am stuck using Revit 2021, I assumed RPS and pyrevit installations from around that time period would be most compatible. I will try reinstalling more up to date versions of the add-ins. Thanks for the suggestions @jpitts @Jean-Marc
rjwein
(Reese)
May 16, 2024, 1:31pm
5
Using the latest installer still allowed me to run RPS for Revit 2021 and fixed the issue. My guess is a .NET version difference. Thanks again!
