Import pyervit moduals to revit pythonshell
is it posible to import pyrevit moduals to use them in the python shell consol? and how?
thanks
Yes. Goto RPS settings and add the full pyrevitlib/ path (inside the pyRevit installation) as the path. Then when import pyrevit, RPS can find pyrevit module in that folder
Doesn’t seem to work for me. :frowning:
Do you mean to add /dev/pyrevitlabs/ to the search paths?
I also tried adding pyrevitlib to the search paths, but then I get import errors stating that ‘wpf’ is not found as a module, and ‘engine’ can’t be found.
I apologize for the typo. I meant pyrevitlib/. Corrected the original answer. Make sure pyRevit is attached using 2.7.7 engine which is the same as RPS
thanks!! that’s ossem!!
ps…
I attached the site Package as well, other wise RPS couldnt fine the modual - pyevent…
and then i can import the forms modualpyrevit
