WIP installer works for me on R2025.2!
thank you!
thank you!
you have to use the WIP installer for pyrevit v5 from this link
That works. Greatly appreciated. Thank you!
Great work all! Thanks so much for that. Much appreciated!
I was really excited to see this and immediately tried to install to give it a go and potentially help debugging, but for some reason I couldnāt get it to install.
I downloaded the pyrevit-installers folder from what I believe is the correct link and I just went through installing the 2 exe files in the (pyRevit_5.0.0.24232_admin_signed.exe and pyRevit_CLI_5.0.0.24232_admin_signed.exe).
Iām not getting any error. Just when I open Revit 2025 I donāt get pyRevit in there.
Is anyone else having the same issue?
Am I doing it wrong?
Hi @AndreaTas ,
Did you uninstall previous versions?
Please file in an issue on the repo with the text or the screen capture of the error.
I havenāt tried the admin installers, but will eventually tomorrow
Thanks @Jean-Marc for the prompt reply mate!
I did uninstall previous versions. After your reply I also tried with the non-admin installers to see if that was the issue and that still doesnāt work.
Although, unfortunately Iām not getting any error and/or error messages. pyRevit just doesnāt show up after I install it. So weird!
Iāll open an issue on GH now. I just thought of asking here before doing that, just in case I was doing something obviously wrong.
Thanks!
Weird, I did not see such an issue in the past 3 years after uninstall.
I installed the latest WIP installers many times around in the past weeks or so.
Could you try and remove also the pyrevit and pyrevit-master folders from %appdata% and program files if any before installing again
@Jean-Marc I did delete anything (files or folders) I could find in the %appdata% folder before installing.
I also tried again just to double-check and it still did not work.
The installer works for me with no issues. I can run it in Revit 2025.
No issues for me, but maybe uninstall the Forma add-in for Revit or disable it if not done already, that thing causes all sorts of issues for me with pyRevit loading.
As well as this try deleting the pyRevit folder in ProgramData if itās still there between installs.
I had somebody else have similar issue. Manually placing the ini file in appdata and programdata fixed. edit to change the name of pyrevit installation to āmasterā in the ini file
[environment]
clones = {"master":"C:\\Program Files\\pyRevit-Master"}
Hello All.
Have tested pyRevit WIP release for Revit 2025 and all of my scripts seem to be working with no issues.
I have a quick question and I do apologize for asking it if someone already answered it - to install pyRevit for Revit 2025 I had to uninstall pyRevit for oldest Revit releases, does that mean I can only have pyRevit for Revit 2025 or Revit < 2025 at one time? Please advise.
Hi @VitalijM ,
The WIP installer should work with all revit versions!
Hey @sanzoghenzo, thatās amazing! Thank you for the reply.
I just install pyRevit_5.0.0.24233 on my computer that had Revit 2023 & 2025.
My extension work fine on Revit 2023 but had some error on Revit 2025.
from System import Uri
from pyrevit.framework import Imaging
class SteamFlow(WPFWindow):
def __init__(self, element):
WPFWindow.__init__(self, "SteamFlow.xaml")
self.img.Source = Imaging.BitmapImage(Uri(__file__.replace('SteamFlow_script.py','Formula.jpg')))
File "C:\xxxx\xxxx\Mechanical.panel\Steam.pulldown\Steam Flow.pushbutton\SteamFlow_script.py", line 19, in <module>
ImportError: Cannot import name Uri
Now I fixed it by
import System
self.img.Source = Imaging.BitmapImage(System.Uri(__file__.replace('SteamFlow_script.py','Formula.jpg')))
I donāt know, this solution is good or not.
from Autodesk.Revit.UI import ExternalEvent
from pyrevit import forms, revit
from System.ComponentModel import ListSortDirection, SortDescription
from System.Windows.Data import CollectionViewSource
class ModelessForm(WPFWindow):
def __init__(self, xamlfile, filters):
WPFWindow.__init__(self, xamlfile)
lvView = CollectionViewSource.GetDefaultView(self.FilterListBox.ItemsSource)
lvView.SortDescriptions.Add(SortDescription("filtername", ListSortDirection.Ascending))
File File "C:\xxxx\xxxx\General.panel\View Override.stack\Filter Visibility.pushbutton\script.py", line 22, in <module>
ImportError: Cannot import name ListSortDirection
Now I fixed it by
from System.ComponentModel import SortDescription
lvView.SortDescriptions.Add(SortDescription("filtername", 0))
I donāt know, whyās Revit 2025 donāt find ENUM ListSortDirection.Ascending
Hi @hs0wkc, welcome to the community!
Please use the triple backticks (```) to enclose code and output messages for better readability; Iāve done it for you this time ![]()
System.dll is now split into multiple assemblies in .NET 8. In this case, the enum (and other things of the System.ComponentModel namespace) are moved to the System.ComponentModel.TypeConverter.dll assembly.@dosymep @Jean-Marc should we track down everything that was included in the āoldā libraries and add them to the assemblies to load? I wonder if we can bypass that list and provide all the loaded libraries directly from c#ā¦
I apologize⦠for my bad format.
I opened an issue for that purpose just for now.
@Jean-Marc
Another thing that will need to be fixed is replace āIntegerValueā property of ElementId with āValueā for 2024+ (IntegerValue works in 2024 but is flagged Obsolete). This occurs extensively throughout pyrevitlib.
Iāll start trickling in some pull requests for these as I come across them, but there quite a few
Edit:
And so I donāt forget⦠Havenāt checked if any of these are used yet
You are right @jpitts I wanted to take care of that myself last year already.
If you donāt mind joining the effort.
thks
