PyTiba not working
Hi all, I’m new to the forum and to the app as a whole, so excuse me if the topic is not on the correct place.
I downloaded pyRevit and pyTiba to use for project in Revit 2021 for export of sheets, the app looks exactly what I need. Unfortunately it gives a mistake and is not working.
I can post the error window if necessary.
Thanks in advance for your time!
Hi, and welcome,
Have a look at QuickStart in the Realm of pyRevit and the Revit API
Please do post the error window image.
The important part tells us which lines and methods are throwing the error.
You also need to give us a way to reproduce the issue. Either a step by step description, a revit file or both.
That being said, pyTiba is maintained by tillbaum (Tillmann Baumeister) · GitHub
You should open an issue
Thanks!
The step-by-step is easy - opening a file, created sheets, try to export them (for me the important functionality is PDF with custom paper size per sheet) - and I get the debug? windows shown in the linked TXT file.
It happens both in my project and in new “virgin” project, created with the default English Systems template.
I will try opening an issue, thanks for the proposal, I don’t have account in Github, will create one.
Thanks again
Hi there, has the issue been resolved? We have the same issue.
I did some digging, it can be fixed manually by creating the folder “ExportDlgValues” inside the “pyTiBa.tab\Export.panel”-folder.
The script expect the folder to exist, and does not create it if missing. The folder is used to store .pkl files for the export settings.
yes thats true. The folder ExportDlgValues must exist and is not created automatically.
My mistake, I will fix that. Thx for pointing it out
