TimHevel
(Tim Hevel)
January 11, 2021, 11:27am
1
In Dynamo 2.6 in Revit 2021 my nodes were invisble. I run pyRevit 4.8.4
After a long search i found out that detaching pyRevit from Revit 2021 solved the problem.
after that i tried attaching a “dynamosafe” version of the engine to Revit 2021 (which is 273). But i got this error from the PyRevitLoader:
I saw similar errors about wpf in dynamo before it was fixed.
any ideas on how to both run dynamo and pyRevit without errors?
eirannejad
(Ehsan Iran-Nejad)
January 12, 2021, 4:48pm
2
@TimHevel Thanks for reporting this. Do you have erros with other engines like 2.7.9 or 2.7.10?
TimHevel
(Tim Hevel)
January 12, 2021, 7:53pm
3
Hi Ehsan,
I just tested 277, 278, 279 and 2710
no errors but same node problem as before for all of them.
I put the dynamologs for all engines plus a file with the differences between 273 and the rest, as far as I could spot, in the link below.
eirannejad
(Ehsan Iran-Nejad)
January 13, 2021, 9:50pm
4
Ok. I’m seriously thinking of recompiling IronPython under a different assembly name. There is so much new conflict coming up with every new release of any addon that uses IronPython. Let me dig into this furthur
TimHevel
(Tim Hevel)
January 14, 2021, 6:21am
5
I’ll sit tight.
In the meantime detaching when I’m using dynamo seems like the best solution.
eirannejad
(Ehsan Iran-Nejad)
January 23, 2021, 12:07am
6
@TimHevel I pushed a major update to pyRevit in the develop branch. If you can checkout this branch and attach to Revit and test the load that would be great. If you can not let me know and I can write instructions here. See this as well
Hi everyone,
Instead of a question, my first post will be about sharing and understanding things for non programmers. I myself struggle quite a bit to get such things done and to understand them.
Let’s say you are interested in trying out a tool that is being developed right now
go to GitHub - eirannejad/pyRevit: Rapid Application Development (RAD) Environment for Autodesk Revit®
click on the master section and it will show you the manages branches where the tool is being developed and trie…
TimHevel
(Tim Hevel)
January 31, 2021, 11:28am
7
Am I doing something wrong?
Jean-Marc
(Jean-Marc Couffin)
February 1, 2021, 11:55am
8
I am guessing it has to do with non compiled code in the develop branch, right @eirannejad
got the same issue while trying to do this on my colleagues computer, It still works on mine but I am 1+ commit back.
eirannejad
(Ehsan Iran-Nejad)
February 1, 2021, 4:42pm
9
@TimHevel Are you on develop branch or the CLI screenshot is from the stock pyRevit 4.8.4? Would you mind adding the --debug switch and capture the results and share?
TimHevel
(Tim Hevel)
February 1, 2021, 5:31pm
10
PS C:\Users\thevel> pyrevit clone develop --dest=C:\Users\thevel\AppData\Roaming\pyrevit-develop --branch=develop
PS C:\Users\thevel> pyrevit attach develop 277 2021
Error: Sequence contains no elements
Run with "--debug" option to see debug messages
PS C:\Users\thevel> pyrevit attach develop latest 2021
PS C:\Users\thevel> pyrevit attach develop latest 2021 --debug
<clone_name> = develop
attach = True
latest = True
<revit_year> = 2021
Debug: Checking for all: wiki
Debug: Missing: wiki
Debug: Checking for all: blog
Debug: Missing: blog
Debug: Checking for all: docs
Debug: Missing: docs
Debug: Checking for all: source
Debug: Missing: source
Debug: Checking for all: youtube
Debug: Missing: youtube
Debug: Checking for all: support
Debug: Missing: support
Debug: Checking for all: env
Debug: Missing: env
Debug: Checking for all: update
Debug: Missing: update
Debug: Checking for all: clone
Debug: Missing: clone
Debug: Checking for all: clones
Debug: Missing: clones
Debug: Checking for all: attach
Debug: Try getting config as dict "environment:clones"
Debug: Try getting config "environment:clones"
Debug: Config "environment:clones" = "{"master":"C:\\Users\\thevel\\AppData\\Roaming\\pyRevit-Master","basex":"C:\\Users\\thevel\\AppData\\Roaming\\pyRevit-basex","develop":"C:\\Users\\thevel\\
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyRevit-Master"
Debug: Searching for valid clones above: C:\Users\thevel\AppData\Roaming\pyRevit-Master
Debug: Checking pyRevit clone validity "C:\Users\thevel\AppData\Roaming\pyRevit-Master"
Debug: Checking clone validity by directory structure...
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyRevit-Master\pyrevitlib"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit"
Debug: Checking pyRevit path "C:\Users\thevel\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit"
Debug: Checking clone validity by git repo...
Debug: Valid pyRevit clone "C:\Users\thevel\AppData\Roaming\pyRevit-Master"
Debug: Valid clone found at: C:\Users\thevel\AppData\Roaming\pyRevit-Master
Debug: Verified clone "master=C:\Users\thevel\AppData\Roaming\pyRevit-Master"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyRevit-basex"
Debug: Searching for valid clones above: C:\Users\thevel\AppData\Roaming\pyRevit-basex
Debug: Checking pyRevit clone validity "C:\Users\thevel\AppData\Roaming\pyRevit-basex"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyRevit-basex\pyrevitlib"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyRevit-basex\pyrevitlib\pyrevit"
Debug: Checking pyRevit path "C:\Users\thevel\AppData\Roaming\pyRevit-basex\pyrevitlib\pyrevit"
Debug: Valid pyRevit clone "C:\Users\thevel\AppData\Roaming\pyRevit-basex"
Debug: Valid clone found at: C:\Users\thevel\AppData\Roaming\pyRevit-basex
Debug: Verified clone "basex=C:\Users\thevel\AppData\Roaming\pyRevit-basex"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop"
Debug: Searching for valid clones above: C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop
Debug: Checking pyRevit clone validity "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop\pyrevitlib"
Debug: Normalized as "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop\pyrevitlib\pyrevit"
Debug: Checking pyRevit path "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop\pyrevitlib\pyrevit"
Debug: Verifying repo validity "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop"
Debug: Valid pyRevit clone "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop"
Debug: Valid clone found at: C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop
Debug: Verified clone "develop=C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop"
Debug: Updating config "environment:clones = {"master":"C:\\Users\\thevel\\AppData\\Roaming\\pyRevit-Master","basex":"C:\\Users\\thevel\\AppData\\Roaming\\pyRevit-basex","develop":"C:\\Users\\t
Debug: Saving config file "C:\Users\thevel\AppData\Roaming\pyRevit\pyRevit_config.ini"
Debug: Normalized as "C:\Users\thevel\develop"
Debug: Attaching on latest engine...
Debug: Engine configuration found: IPY273
Debug: "kernel" : "IronPython"
Debug: "version" : "273"
Debug: "runtime" : "true"
Debug: "assembly" : "pyRevitLoader.dll"
Debug: "description" : "IronPython Engine"
Debug: Error parsing clone "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop" engines configs from "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop\PyRevitfile" | No row with key
Error: Sequence contains no elements (System.InvalidOperationException)
at System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
at pyRevitCLI.PyRevitCLI.ProcessArguments()
at pyRevitCLI.PyRevitCLI.Main(String[] args)
develop | Branch: "develop" | Version: "4.8.4:450dbe9" | Path: "C:\Users\thevel\AppData\Roaming\pyrevit-develop\develop"
master | Deploy: "basepublic" | Branch: "master" | Version: "4.8.4" | Path: "C:\Users\thevel\AppData\Roaming\pyRevit-Master"
PS C:\Users\thevel> pyrevit clones
basex | Deploy: "basex" | Branch: "master" | Version: "4.8.4" | Path: "C:\Users\thevel\AppData\Roaming\pyRevit-basex"
PS C:\Users\thevel> pyrevit switch develop
PS C:\Users\thevel> pyrevit clone dev --dest="C:\Users\thevel\AppData\Roaming\pyRevit-dev" --branch=develop
PS C:\Users\thevel> pyrevit attach dev latest 2021
dev | Branch: "develop" | Version: "4.8.4:450dbe9" | Path: "C:\Users\thevel\AppData\Roaming\pyRevit-dev\dev"
eirannejad
(Ehsan Iran-Nejad)
February 1, 2021, 6:23pm
11
@TimHevel Yes. there has been changes to how engines work on the develop branch. The CLI is returning an error since the CLI version is actually older than the one on the develop branch. If you are not familiar with compiling pyRevit from the develop branch locally, then please disregard my request to test. I’ll release 4.8.5 soon and will let you know how to test it with that release
Jean-Marc
(Jean-Marc Couffin)
February 2, 2021, 8:07am
12
I would be interest in knowing how to compile from the dev branch with a little guidance.
TimHevel
(Tim Hevel)
February 2, 2021, 5:05pm
13
If you could write instructions for us, please.
Lets see how far i can get.
TimHevel
(Tim Hevel)
March 23, 2021, 11:12am
14
I installed 4.8.5 and set it up with the new IronPython 2711 engine and im still having the same problems unfortunately.
Jean-Marc
(Jean-Marc Couffin)
March 24, 2021, 12:40pm
15
running 4.8.6 and 2711 engin, no issue
one of my colleagues got the same kind of issue. pinned down on sysque addin in Revit. but hard to track as hell as uninstalling installing one way or the other did not always solved the issue. also some packages in dynamo were causing trouvle (archilabs - bakery if I remember well)
TimHevel
(Tim Hevel)
March 24, 2021, 12:51pm
16
Yes it is an issue that can occur with any number of addins not just pyRevit.
but in my case dynamo works fine when I detach pyRevit.
TimHevel
(Tim Hevel)
August 31, 2021, 12:40pm
17
finally got around to testing what is wrong.
It had to do with a conflict between the Archi-lab_Mandrill package and pyRevit. after deleting the package Dynamo and pyRevit work fine again.
