For sure! Here is a cleaned up sample of a dockable pane that gets dynamically updated with the id values of whatever is selected in the document. This is built on the Dockable Pane sample in the DevTools extension with some tweaks derived from solutions to some of my other questions on this forum.
This first bit of code is the startup.py file that gets put in the root of the extension folder.
#pylint: disable=import-error,invalid-name,broad-except,superfluous-parens
#pylint: disable=unused-import,wrong-import-position,unused-argument
#pylint: disable=missing-docstring
import System
import os.path as op
from pyrevit import HOST_APP, framework, coreutils, PyRevitException
from pyrevit.framework import wpf, ObservableCollection
sample_panel_id = "1458b7cb-4dbe-4a8e-bad3-837e14b0a1ca"
selected = []
def idling_eventhandler(sender, args):
try: dockable_pane = UI.DockablePane(UI.DockablePaneId(System.Guid(sample_panel_id)))
except: return
global selected
if HOST_APP.uidoc and dockable_pane.IsShown():
ids = sorted(HOST_APP.uidoc.Selection.GetElementIds())
if ids:
if ids != selected:
selected = ids
registered_panel.update_list()
if selected:
selected = []
print e.message
HOST_APP.uiapp.Idling += \
framework.EventHandler[UI.Events.IdlingEventArgs](idling_eventhandler)
class _WPFPanelProvider(UI.IDockablePaneProvider):
def __init__(self, panel_type, default_visible=True):
self._panel_type = panel_type
self._default_visible = default_visible
self.panel = self._panel_type()
def SetupDockablePane(self, data):
data.FrameworkElement = self.panel
data.VisibleByDefault = self._default_visible
def register_dockable_panel(panel_type, default_visible=True):
if not issubclass(panel_type, forms.WPFPanel):
raise PyRevitException(
"Dockable pane must be a subclass of forms.WPFPanel"
panel_uuid = coreutils.Guid.Parse(panel_type.panel_id)
dockable_panel_id = UI.DockablePaneId(panel_uuid)
panel_provider = _WPFPanelProvider(panel_type, default_visible)
HOST_APP.uiapp.RegisterDockablePane(
dockable_panel_id,
panel_type.panel_title,
panel_provider
return panel_provider.panel
class DockableExample(forms.WPFPanel):
panel_source = op.join(op.dirname(__file__), "DockablePaneSample.xaml")
panel_title = "Dockable Pane Sample"
panel_id = sample_panel_id
def __init__(self):
wpf.LoadComponent(self, self.panel_source)
self.thread_id = framework.get_current_thread_id()
self.selected_lb.ItemsSource = []
def update_list(self):
template_list = [forms.TemplateListItem(s.IntegerValue) for s in selected]
self.selected_lb.ItemsSource = ObservableCollection[forms.TemplateListItem](template_list)
print e.message
registered_panel = register_dockable_panel(DockableExample)
This second bit of code is the XAML for the dockable panel. It goes in that same root folder. Gotta make sure the file name is matching whatever is in the above code.
<Page xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
Background="White">
<Page.Resources>
<ControlTemplate x:Key="ItemTemplate">
<TextBlock Text="{Binding name}"
ToolTip="{Binding name}"
VerticalAlignment="Center"
Margin="10,0,0,0">
</TextBlock>
</ControlTemplate>
<DataTemplate x:Key="ItemContainerTemplate">
<Grid>
<Grid.ColumnDefinitions>
<ColumnDefinition Width="Auto"/>
</Grid.ColumnDefinitions>
<Control Grid.Column="0"
VerticalAlignment="Center" VerticalContentAlignment="Center"
Template="{DynamicResource ItemTemplate}">
</Control>
</Grid>
</DataTemplate>
<ItemsPanelTemplate x:Key="ItemsPanelTemplate">
<StackPanel />
</ItemsPanelTemplate>
</Page.Resources>
<DockPanel>
<TextBlock DockPanel.Dock="Top"
Text="Selected Elements"
HorizontalAlignment="Stretch"
Background="#FFEEEEEE"/>
<ListView x:Name="selected_lb"
ItemTemplate ="{DynamicResource ItemContainerTemplate}"
ItemsPanel="{DynamicResource ItemsPanelTemplate}">
</ListView>
</DockPanel>
</Page>
And finally you need to add a button to open the panel. Here is the code for that.
__title__ = 'Open\nPanel'
__context__ = 'zero-doc'
test_panel_uuid = "1458b7cb-4dbe-4a8e-bad3-837e14b0a1ca"
forms.open_dockable_panel(test_panel_uuid)
I think that’s everything and I hope I copy and pasted it in here all correctly. Give it a test and let me know if something isn’t working.
