I’ve built a dockable pane, I’ve read lots of forum posts such as these:
I am still learning here, so please be gentle.
I want to return the doc (which loads after the pane), for things like ‘doc.GetWarnings()’
I see doc can be called in a number of ways, revit.doc, doc = HOST_APP.doc etc. I am clearly missing something, because I get 'nonType object has no attrribute ‘GetWarnings’ when I click my button.
Any assistance appreciated!
import System
import os.path as op
from pyrevit import HOST_APP, framework, coreutils, PyRevitException
from pyrevit.framework import wpf, ObservableCollection
from pyrevit import routes
import time
class _WPFPanelProvider(UI.IDockablePaneProvider):
def __init__(self, panel_type, default_visible=True):
self._panel_type = panel_type
self._default_visible = default_visible
self.panel = self._panel_type()
def SetupDockablePane(self, data):
data.FrameworkElement = self.panel
data.VisibleByDefault = self._default_visible
def register_dockable_panel(panel_type, default_visible=True):
if not issubclass(panel_type, forms.WPFPanel):
raise PyRevitException(
"Dockable pane must be a subclass of forms.WPFPanel"
panel_uuid = coreutils.Guid.Parse(panel_type.panel_id)
dockable_panel_id = UI.DockablePaneId(panel_uuid)
panel_provider = _WPFPanelProvider(panel_type, default_visible)
HOST_APP.uiapp.RegisterDockablePane(
dockable_panel_id,
panel_type.panel_title,
panel_provider
return panel_provider.panel
class DockableExample(forms.WPFPanel):
panel_title = "OBE Info Pane"
panel_id = "1458b7cb-4dbe-4a8e-bad3-837e14b0a1ca"
panel_source = "Z:\\Library\\BIM\\01 Revit\\05 Toolbar\\OBTool\\Oberlanders.extension\\OBE.tab\\Audit.Panel\\AuditStack.Stack\\Dockable.pushbutton\\dockable.xaml"
def __init__(self):
wpf.LoadComponent(self, self.panel_source)
self.thread_id = framework.get_current_thread_id()
self.selected_lb.Text = ""
def button_click(self, sender, args):
from obe import model_audit_doc #if we call at the start there is no doc?
wrn = doc.GetWarnings() #test call fails
data_string = "test"
self.selected_lb.Text = data_string
print e.message
registered_panel = register_dockable_panel(DockableExample)
I experimented a bit on my side.
This is definitely not a topic I fully grasp.
I started from the sample in the dev extension of pyRevit
The key seems to be to handle what is related to the Document in the EventHandler definition
I used the ViewActivated one, getting its arguments ‘args’ you can grab the Document and build from there.
python code in my 'startup.py' script
import System
sample_panel_id = "1458b7cb-4dbe-4a8e-bad3-837e14b0a1ca"
warnings_list = []
dockable_panel_id,
panel_provider
panel_source = op.join(op.dirname(__file__), "DockablePaneSample.xaml")
panel_title = "Dockable Pane Sample"
panel_id = sample_panel_id
def __init__(self):
self.warnings_lb.ItemsSource = []
def update_list(self):
template_list = [forms.TemplateListItem(w) for w in warnings_list]
self.warnings_lb.ItemsSource = ObservableCollection[forms.TemplateListItem](template_list)
print e.message
def viewactivated_eventhandler(sender, args):
try: dockable_pane = UI.DockablePane(UI.DockablePaneId(System.Guid(sample_panel_id)))
except: return
global warnings_list
if HOST_APP.uidoc and dockable_pane.IsShown():
warns = args.Document.GetWarnings()
warns = [i.GetDescriptionText() for i in warns]
print warns
# you could print here to check if it's working
if warns:
warnings_list = warns
registered_panel.update_list()
print e.message
HOST_APP.uiapp.ViewActivated += \
framework.EventHandler[UI.Events.ViewActivatedEventArgs](viewactivated_eventhandler)
