Well, I still have not solved the original issue, but I found what should have been an obvious workaround. The pop-up dialog that triggers the unresponsiveness can be avoided by opening the element’s owner view before showing the element. That way, there is no need to dismiss the dialog in the first place.
For anyone following who wants to use this code, here are the files:
bundle.yaml file:
engine:
  persistent: true
title: "Fix Room\nTags"
tooltip: Finds errant room tags and allows the user to fix them.
author: Frank Loftus
script.py file:
# dependencies
# Import from pyrevit
from pyrevit import UI
from pyrevit.revit import Transaction as pyrevit_transaction
##from pyrevit.revit import doc # Alternative way to access doc through pyrevit
xamlfile = script.get_bundle_file('ui.xaml') # find the path of ui.xaml
# import WPF creator and base Window
import wpf
from System import Windows
from System import EventHandler as WinEventHandler
# import python system module
# Import ctypes for access to SetForegroundWindow(). No longer used.
import ctypes
# Import Revit API objects
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import ViewType, Transaction, ElementId, FilteredElementCollector, BuiltInCategory, BuiltInParameter, Element, RevitLinkInstance
from Autodesk.Revit.DB.Architecture import RoomTag, Room
from Autodesk.Revit.UI import UIDocument, Selection, TaskDialog, TaskDialogResult, IExternalEventHandler, ExternalEvent
from Autodesk.Revit.UI.Events import DialogBoxShowingEventArgs, TaskDialogShowingEventArgs
from Autodesk.Revit.UI.UIDocument import GetOpenUIViews, ActiveView, ShowElements
# Import .NET List
# Global variables
script_name = 'Fix Room Tags'
GLOBAL_DEBUG = False
# Toggleable print function. Turn on to debug.
def p(*to_print):
	if GLOBAL_DEBUG:
		for item in to_print:
			print item
# Setup doc
uiapp = __revit__
def dismiss_dialog (sender, event_args): #### No longer used.
	id_ok = 1
		p('type(event_args):', type(event_args))
		if isinstance(event_args, TaskDialogShowingEventArgs):
			p('dismissing dialog {}. Cancellable: {}'.format(event_args.DialogId, event_args.Cancellable))
			result = event_args.OverrideResult(id_ok)
			p('dismissed:', result)
	except Exception as ex:
		# Hacky way to catch and print exceptions within:
		print('Error on line {}'.format(sys.exc_info()[-1].tb_lineno), type(ex).__name__, ex)
		print(sys.exc_info()[-1].tb_next.tb_lineno)
		print(sys.exc_info()[-1].tb_next.tb_next.tb_lineno)
		print(sys.exc_info()[-1].tb_next.tb_next.tb_next.tb_lineno)
		print(sys.exc_info()[-1].tb_next.tb_next.tb_next.tb_next.tb_lineno)
		print(sys.exc_info()[-1].tb_next.tb_next.tb_next.tb_next.tb_next.tb_lineno)
def show_element_OBSOLETE(element): #### No longer used
	if element:
		global uidoc
		# Use a windows EventHandler to dismiss the pop-up dialog upon ShowElements()
		dialog_event_handler = WinEventHandler[DialogBoxShowingEventArgs](dismiss_dialog)
		uiapp.DialogBoxShowing += dialog_event_handler
		uidoc.ShowElements(element)
		uiapp.DialogBoxShowing -= dialog_event_handler
def show_element(element):
	if element:
		global uidoc
		# Acquire tag's OwnerView and open it before ShowElements() to avoid pop-up dialog
		active_view = uidoc.ActiveView
		owner_view_id = element.OwnerViewId
		if active_view.Id != owner_view_id:
			owner_view = doc.GetElement(owner_view_id)
			uidoc.ActiveView = owner_view
# Create a subclass of IExternalEventHandler
class EventHandler(IExternalEventHandler):
	def __init__(self, func_to_run):
		self.func = func_to_run
	def Execute(self, uiapp):
			self.func()
			# Hacky way to catch and print exceptions within Execute():
	def GetName(self):
		return "simple function executed by an IExternalEventHandler in a Form"
class ListItem:
	def __init__(self, elem):
		# Initial properties
		self.elem            = elem
		self.elem_id         = elem.Id
		self.elem_id_str     = self.elem_id.ToString()
		self.status          = self.status
		self.owner_view_id   = elem.OwnerViewId
		self.owner_view      = doc.GetElement(self.owner_view_id)
		self.owner_view_name = self.owner_view.Name
		self.room_number     = self.room.Number if self.room else ''
		self.room_name       = self.room.get_Parameter(BuiltInParameter.ROOM_NAME).AsString() if self.room else 'No Room'
	@property
	def status(self):
		if self.elem.IsOrphaned:
			return '(Orphaned)'
		elif not self.elem.IsInRoom:
			return '(Misplaced)'
			return False
	@property
	def room(self):
		if not self.elem.IsOrphaned:
			if self.elem.IsTaggingLink:
				linked_element_id         = self.elem.TaggedRoomId.LinkedElementId
				link_instance_id          = self.elem.TaggedRoomId.LinkInstanceId
				link_instance             = doc.GetElement(link_instance_id)
				link_doc                  = link_instance.GetLinkDocument()
				linked_room               = link_doc.GetElement(linked_element_id)
				return linked_room
				tagged_local_room = doc.GetElement(self.elem.TaggedLocalRoomId)
				return tagged_local_room
		else: p('tag is orphaned. cannot find tagged room.')
	@property
	def display_string(self):
		return '{}, {}, {} {}, View: {}'.format(self.status, self.elem_id_str, self.room_name, self.room_number, self.owner_view_name)
class Display:
	def __init__(self, form, model=None, view=None):
		self.form = form
		self.model = model
		self.view = view
	def refresh_model(self):
		self.model = self.form.list_items_in_model
		self.form.listbox_entire_model.ItemsSource = [list_item.display_string for list_item in self.model]
	def refresh_view(self):
		self.view = self.form.list_items_in_view
		self.form.listbox_current_view.ItemsSource = [list_item.display_string for list_item in self.view]
	def set_model(self, list_items):
		self.model = list_items
		self.form.listbox_entire_model.ItemsSource = [list_item.display_string for list_item in list_items]
	def set_view(self, list_items):
		self.view = list_items
		self.form.listbox_current_view.ItemsSource = [list_item.display_string for list_item in list_items]
# WPF form used to call the ExternalEvents
class ModelessForm(WPFWindow):
		WPFWindow.__init__(self, xaml_file_name)
		self.current_tag_index      = 0
		self.recentered_list_item   = None
		self.recentered_list_items  = None
		self.current_tag            = None
		self.display                = Display(self)
		# Create instance of handler, then instance of event for each button/command
		self.refresh_window_handler = EventHandler(self.refresh_window)
		self.refresh_window_event_instance = ExternalEvent.Create(self.refresh_window_handler)
		self.listbox_current_view_selection_change_handler = EventHandler(self.listbox_current_view_selection_change)
		self.listbox_current_view_selection_change_event_instance = ExternalEvent.Create(self.listbox_current_view_selection_change_handler)
		self.listbox_current_view_got_focus_handler = EventHandler(self.listbox_current_view_got_focus)
		self.listbox_current_view_got_focus_event_instance = ExternalEvent.Create(self.listbox_current_view_got_focus_handler)
		self.recenter_selected_tag_handler = EventHandler(self.recenter_selected_tag)
		self.recenter_selected_tag_event_instance = ExternalEvent.Create(self.recenter_selected_tag_handler)
		self.delete_selected_tag_handler = EventHandler(self.delete_selected_tag)
		self.delete_selected_tag_event_instance = ExternalEvent.Create(self.delete_selected_tag_handler)
		self.listbox_entire_model_selection_change_handler = EventHandler(self.listbox_entire_model_selection_change)
		self.listbox_entire_model_selection_change_event_instance = ExternalEvent.Create(self.listbox_entire_model_selection_change_handler)
		self.listbox_entire_model_got_focus_handler = EventHandler(self.listbox_entire_model_got_focus)
		self.listbox_entire_model_got_focus_event_instance = ExternalEvent.Create(self.listbox_entire_model_got_focus_handler)
		self.recenter_all_tags_in_view_handler = EventHandler(self.recenter_all_tags_in_view)
		self.recenter_all_tags_in_view_event_instance = ExternalEvent.Create(self.recenter_all_tags_in_view_handler)
		self.delete_all_orphans_in_view_handler = EventHandler(self.delete_all_orphans_in_view)
		self.delete_all_orphans_in_view_event_instance = ExternalEvent.Create(self.delete_all_orphans_in_view_handler)
		self.delete_room_tags_not_visible_in_any_view_handler = EventHandler(self.delete_room_tags_not_visible_in_any_view)
		self.delete_room_tags_not_visible_in_any_view_event_instance = ExternalEvent.Create(self.delete_room_tags_not_visible_in_any_view_handler)
		self.next_tag_handler = EventHandler(self.next_tag)
		self.next_tag_event_instance = ExternalEvent.Create(self.next_tag_handler)
		self.previous_tag_handler = EventHandler(self.previous_tag)
		self.previous_tag_event_instance = ExternalEvent.Create(self.previous_tag_handler)
		# Populate ListBox with RoomTags from model
		self.display.refresh_model()
		self.display.refresh_view()
		# Populate item quantities
		self.textblock_quantity_in_model.Text = self.quantity_in_model_str
		self.textblock_view_name.Text         = self.active_ui_view.Name
		self.textblock_quantity_in_view.Text  = self.quantity_in_view_str
		# Show modeless window
		self.show_self()
	# Properties
	@property
	def active_ui_view(self):
		return uidoc.ActiveView
	@property
	def link_instances(self): #### Not used currently.
		result = FilteredElementCollector(doc).OfClass(RevitLinkInstance)
		p('linked_models:', result)
		return result
	@property
	def link_documents(self): #### Not used currently.
		if self.link_instances:
			result = [instance.GetLinkDocument() for instance in self.link_instances]
			result_cleaned = [document for document in result if document is not None]
			p('link_documents:', result_cleaned)
			return result_cleaned
		else: p('No link instances. Cannot create link_documents.')
	@property
	def link_titles(self): #### Not used currently.
		if self.link_documents:
			result = [document.Title for document in self.link_documents]
			p('link_titles:', result)
			return result
		else: p('No link documents. Cannot create link_titles.')
	@property
	def room_tags_in_model(self):
		result = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RoomTags).WhereElementIsNotElementType()
		p('room_tags_in_model:', result)
		if result: return result
		else: p('No room tags in model.')
	@property
	def room_tag_owner_view_ids_in_model_set(self):
		if self.room_tags_in_model:
			result = set([tag.OwnerViewId for tag in self.room_tags_in_model])
			p('room_tag_owner_view_ids_in_model_set:', result)
			return result
		else: p('No room tags in model. Cannot make room_tag_owner_view_ids_in_model_set.')
	@property
	def room_tags_visible_in_model(self):
		room_tags_visible_in_model = List[Element]()
		if self.room_tag_owner_view_ids_in_model_set:
			for owner_view_id in self.room_tag_owner_view_ids_in_model_set:
				room_tags_visible_in_view = FilteredElementCollector(doc, owner_view_id).OfCategory(BuiltInCategory.OST_RoomTags).WhereElementIsNotElementType().ToElements()
				room_tags_visible_in_model.AddRange(room_tags_visible_in_view)
			p('room_tags_visible_in_model:', [tag.Id.ToString() for tag in room_tags_visible_in_model])
			return room_tags_visible_in_model
		else: p('No room_tag_owner_view_ids_in_model_set. Cannot make room_tags_visible_in_model')
	@property
	def room_tag_ids_not_visible_in_any_view(self):
		room_tags_in_model = self.room_tags_in_model
		if room_tags_in_model:
			room_tag_ids_in_model = [tag.Id.IntegerValue for tag in room_tags_in_model]
			room_tag_ids_in_model_set = set(room_tag_ids_in_model)
			p('room_tags_in_model_set:', [tag_id for tag_id in room_tag_ids_in_model_set])
			if self.room_tags_visible_in_model:
				room_tags_visible_in_model_list = self.room_tags_visible_in_model
				room_tag_ids_visible_in_model = [tag.Id.IntegerValue for tag in room_tags_visible_in_model_list]
				room_tag_ids_visible_in_model_set = set(room_tag_ids_visible_in_model)
				set_diff = room_tag_ids_in_model_set.difference(room_tag_ids_visible_in_model_set)
				result = [ElementId(tag_id_string) for tag_id_string in set_diff]
				p('room_tags_not_visible_in_any_view:', [tag_id.IntegerValue for tag_id in result])
				return result
			else: p('no room tags visible in model. cannot make room_tags_not_visible_in_any_view')
		else: p('no room tags in model. cannot make room_tags_not_visible_in_any_view')
	@property
	def room_tags_in_view(self):
		result = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RoomTags).WhereElementIsNotElementType().OwnedByView(self.active_ui_view.Id)
		p('room_tags_in_view:', result)
		return result
	@property
	def orphaned_room_tags_in_model(self):
		result = [room_tag for room_tag in self.room_tags_in_model if room_tag.IsOrphaned]
		p('orphaned_room_tags_in_model:', result)
		return result
	@property
	def misplaced_room_tags_in_model(self):
		result = [room_tag for room_tag in self.room_tags_in_model if not room_tag.IsInRoom]
		p('misplaced_room_tags_in_model:', result)
		return result
	@property
	def orphaned_or_misplaced_room_tags_in_model(self):
		result = [room_tag for room_tag in self.room_tags_in_model if room_tag.IsOrphaned or not room_tag.IsInRoom]
		p('orphaned_or_misplaced_room_tags_in_model:', [elem.Id for elem in result])
		return result
	@property
	def list_items_in_model(self):
		result = [ListItem(room_tag) for room_tag in self.room_tags_in_model if room_tag.IsOrphaned or not room_tag.IsInRoom]
		p('orphaned_or_misplaced_room_tags_in_model:', [list_item.elem.Id for list_item in result])
		return result
	@property
	def display_strings_in_model(self):
		return [list_item.display_string for list_item in self.display.model]
	@property
	def quantity_in_model(self):
		result = len(self.orphaned_or_misplaced_room_tags_in_model)
		p('quantity_in_model:', result)
		return result
	@property
	def quantity_in_model_str(self):
		return str(self.quantity_in_model)
	@property
	def tag_ids_in_model(self):
		result = [tag.Id for tag in self.orphaned_or_misplaced_room_tags_in_model]
		p('tag_ids_in_model:', result)
		return result
	@property
	def recentered_tag_ids(self):
		return [tag.Id for tag in self.recentered_tags]
	@property
	def recentered_list_item_ids(self):
		return [list_item.elem.Id for list_item in self.recentered_list_items]
	@property
	def recentered_display_strings(self):
		return [list_item.display_string for list_item in self.recentered_list_items]
	@property
	def orphaned_in_view(self):
		result = [room_tag for room_tag in self.room_tags_in_view if room_tag.IsOrphaned]
		p('orphaned_in_view:', [elem.Id for elem in result])
		return result
	@property
	def misplaced_in_view(self):
		result = [room_tag for room_tag in self.room_tags_in_view if not room_tag.IsInRoom]
		p('misplaced_in_view:', [elem.Id for elem in result])
		return result
	@property
	def orphaned_or_misplaced_room_tags_in_view(self):
		result = [room_tag for room_tag in self.room_tags_in_view if room_tag.IsOrphaned or not room_tag.IsInRoom]
		p('orphaned_or_misplaced_room_tags_in_view:', [elem.Id for elem in result])
		return result
	@property
	def list_items_in_view(self):
		result = [ListItem(room_tag) for room_tag in self.room_tags_in_view if room_tag.IsOrphaned or not room_tag.IsInRoom]
		p('orphaned_or_misplaced_room_tags_in_view:', [list_item.elem.Id for list_item in result])
		return result
	@property
	def display_strings_in_view(self):
		return [list_item.display_string for list_item in self.display.view]
	@property
	def tag_ids_in_current_view(self):
		result = [tag.Id for tag in self.orphaned_or_misplaced_room_tags_in_view]
		p('tag_ids_in_current_view:', result)
		return result
	@property
	def quantity_in_view(self):
		result = len(self.orphaned_or_misplaced_room_tags_in_view)
		p('quantity_in_view:', result)
		return result
	@property
	def quantity_in_view_str(self):
		return str(self.quantity_in_view)
	# Methods
	def regain_focus(self): #### No longer used.
		ctypes.windll.user32.SetForegroundWindow(self.as_foreground_window)
	def show_self(self):
		self.Show()
		# Set self as foreground window. No longer used.
		self.as_foreground_window = ctypes.windll.user32.GetForegroundWindow()
		p('foreground window:', self.as_foreground_window)
	def recenter_tag(self, tag):
		if not tag:  p('no input tag. cannot recenter_tag()')
		else: # If tag exists:
			if tag.IsOrphaned: p('tag is orphaned. cannot recenter_tag()')
			else: # If tag can be recentered:
				if tag.IsTaggingLink:
					linked_element_id         = tag.TaggedRoomId.LinkedElementId
					link_instance_id          = tag.TaggedRoomId.LinkInstanceId
					link_instance_transform   = link_instance.GetTransform()
					room_location             = linked_room.Location
					tag.Location.Point        = link_instance_transform.OfPoint(room_location.Point)
					self.recentered_list_item = ListItem(tag)
				else: # If tag is tagging local room in host model:
					tagged_local_room         = doc.GetElement(tag.TaggedLocalRoomId)
					room_location             = tagged_local_room.Location
					tag.Location.Point        = room_location.Point
	# Methods to call via external event
	def refresh_window(self):
		button_name = 'refresh_window'
		new_window = ModelessForm("ui.xaml")
		self.Close()
		p('{} succeeded'.format(button_name))
	def listbox_entire_model_selection_change(self):
		button_name = 'listbox_entire_model_selection_change'
		selected_index = self.listbox_entire_model.SelectedIndex
		if selected_index > -1:
			self.current_tag = self.display.model[selected_index].elem
			if len(self.display.model) > 0:
				show_element(self.current_tag)
			self.refresh_listboxes_and_quantities()
			self.current_tag_index = selected_index
		else: p('selected_index not > -1. Likely no list items in listbox.')
	def listbox_entire_model_got_focus(self):
		self.listbox_entire_model_selection_change()
	def listbox_current_view_selection_change(self):
		button_name = 'listbox_current_view_selection_change'
		selected_index = self.listbox_current_view.SelectedIndex
			self.current_tag = self.display.view[selected_index].elem
			if len(self.display.view) > 0:
				elems_in_model = [item.elem_id for item in self.display.model]
				self.current_tag_index = elems_in_model.index(self.current_tag.Id)
	def listbox_current_view_got_focus(self):
		self.listbox_current_view_selection_change()
	def recenter_selected_tag(self):
		button_name = 'recenter_selected_tag'
		if self.current_tag:
			if not self.current_tag.IsOrphaned:
				with pyrevit_transaction("Recenter room tag"):
					self.recenter_tag(self.current_tag)
				show_element(self.recentered_list_item.elem)
		else: p('no current_tag. cannot recenter_selected_tag()')
	def refresh_listboxes(self):
	def refresh_quantities(self):
	def refresh_active_view_text(self):
	def refresh_listboxes_and_quantities(self):
		self.refresh_listboxes()
		self.refresh_quantities()
		self.refresh_active_view_text()
	def delete_selected_tag(self):
			button_name = 'delete_selected_tag'
			p('deleting selected_tag {}'.format(self.current_tag.Id))
			with pyrevit_transaction("Delete room tag"):
				doc.Delete(self.current_tag.Id)
		else: p('no current tag. cannot delete_selected_tag()')
	def recenter_all_tags_in_view(self):
		misplaced_in_view = self.misplaced_in_view
		if misplaced_in_view:
			button_name = 'recenter_all_tags_in_view'
			recentered_list_items = []
			with pyrevit_transaction("Recenter all room tags in view"):
				for tag in misplaced_in_view:
					self.recenter_tag(tag)
					recentered_list_items.append(ListItem(tag))
			self.recentered_list_items = recentered_list_items
			self.display.set_view(self.recentered_list_items)
			if self.display.view: show_element(self.display.view[0].elem)
		else: p('no misplaced tags in view. cannot recenter_all_tags_in_view()')
	def delete_all_orphans_in_view(self):
		button_name = 'delete_all_orphans_in_view'
		with pyrevit_transaction("Delete orphaned room tags in view"):
			for tag in self.orphaned_in_view:
				doc.Delete(tag.Id)
	def delete_room_tags_not_visible_in_any_view(self):
		button_name = 'delete room tags not visible in any view'
		if self.room_tag_ids_not_visible_in_any_view:
			with pyrevit_transaction("Delete room tags not visible in any view"):
				for tag_id in self.room_tag_ids_not_visible_in_any_view:
					doc.Delete(tag_id)
		else: p('No self.room_tag_ids_not_visible_in_any_view. Cannot delete_room_tags_not_visible_in_any_view()')
	def next_tag(self):
		button_name = 'next_tag'
		if self.current_tag_index < len(self.display.model) - 1:
			self.current_tag_index += 1
			p('Current Tag Index: ', self.current_tag_index)
			show_element(self.display.model[self.current_tag_index].elem)
		else: p('There is no next tag to show.')
	def previous_tag(self):
		button_name = 'previous_tag'
		if self.current_tag_index >= 1 < len(self.display.model):
			self.current_tag_index -= 1
		else: p('There is no previous tag to show.')
	# Events to call from xaml UI
	def close_window(self, sender, args):
		self.Close()
	def refresh_window_event(self, sender, args):
		self.refresh_window_event_instance.Raise()
	def listbox_entire_model_selection_change_event(self, sender, args):
		self.listbox_entire_model_selection_change_event_instance.Raise()
	def listbox_entire_model_got_focus_event(self, sender, args):
		self.listbox_entire_model_got_focus_event_instance.Raise()
	def listbox_current_view_selection_change_event(self, sender, args):
		self.listbox_current_view_selection_change_event_instance.Raise()
	def listbox_current_view_got_focus_event(self, sender, args):
		self.listbox_current_view_got_focus_event_instance.Raise()
	def recenter_selected_tag_event(self, sender, args):
		self.recenter_selected_tag_event_instance.Raise()
	def delete_selected_tag_event(self, sender, args):
		self.delete_selected_tag_event_instance.Raise()
	def recenter_all_tags_in_view_event(self, sender, args):
		self.recenter_all_tags_in_view_event_instance.Raise()
	def delete_all_orphans_in_view_event(self, sender, args):
		self.delete_all_orphans_in_view_event_instance.Raise()
	def delete_room_tags_not_visible_in_any_view_event(self, sender, args):
		self.delete_room_tags_not_visible_in_any_view_event_instance.Raise()
	def next_tag_event(self, sender, args):
		self.next_tag_event_instance.Raise()
	def previous_tag_event(self, sender, args):
		self.previous_tag_event_instance.Raise()
# Instantiate the form
modeless_form = ModelessForm("ui.xaml")
ui.xaml file:
		xmlns:av="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:Collections="clr-namespace:System.Collections;assembly=mscorlib" mc:Ignorable="av"
		Title="Fix Room Tags" ResizeMode="NoResize" SizeToContent="WidthAndHeight" Background="WhiteSmoke" BorderBrush="#FF89AF98" Topmost="True">
	<StackPanel x:Name="main_stackpanel" Margin="10">
		<StackPanel Orientation="Horizontal" Margin="0,10,0,0">
			<StackPanel Orientation="Vertical" Margin="0,0,10,0">
                <!--<ComboBox x:Name="select_arch_model_combo_box" SelectionChanged="select_arch_model_event" Text="Select Architectural Model" Background="#FF89AF98" Foreground="Black" MinWidth="155" Margin="0,0,0,10">
				</ComboBox>-->
                <Button x:Name="delete_room_tags_not_visible_in_any_view_button" Click="delete_room_tags_not_visible_in_any_view_event" Content="Delete room tags not visible in any view" Padding="5,1,5,1" HorizontalContentAlignment="Left" Margin="0,1,0,11"/>
                <StackPanel Orientation="Horizontal" Margin="0,0,0,0">
					<TextBlock Text="Errant tags in entire model:" Padding="1,0,5,0" Margin="0,0,0,5" />
                    <TextBlock x:Name="textblock_quantity_in_model" Text="#" Padding="5,0,5,0" Margin="0,0,0,5" />
                </StackPanel>
                <ListBox x:Name="listbox_entire_model" GotFocus="listbox_entire_model_got_focus_event" SelectionChanged="listbox_entire_model_selection_change_event" Margin="0,0,0,10" Height="100" />
                <Button x:Name="recenter_selected_tag_button" Click="recenter_selected_tag_event" Content="Re-center Selected Tag" HorizontalContentAlignment="Left" Padding="5,1,1,1" />
                <Button x:Name="delete_selected_tag_button" Click="delete_selected_tag_event" Content="Delete Selected Tag" HorizontalContentAlignment="Left" Padding="5,1,1,1" />
            </StackPanel>
			<StackPanel Orientation="Vertical">
                <Button x:Name="refresh_button_Copy" Click="refresh_window_event" Content="Refresh" Padding="5,1,5,1" HorizontalContentAlignment="Right" Margin="0,1,0,11"/>
                    <TextBlock Text="In current view:" Padding="1,0,5,0" Margin="0,0,0,5" />
                    <TextBlock x:Name="textblock_view_name" Text="Current View Name" Padding="5,0,5,0" Margin="0,0,0,5" />
                    <TextBlock x:Name="textblock_quantity_in_view" Text="#" Padding="5,0,5,0" Margin="0,0,0,5" />
                </StackPanel>
                <ListBox x:Name="listbox_current_view" GotFocus="listbox_current_view_got_focus_event" SelectionChanged="listbox_current_view_selection_change_event" Margin="0,0,0,10" Height="100" >
				</ListBox>
                <Button Content="Re-center All Tags in View" Click="recenter_all_tags_in_view_event" HorizontalContentAlignment="Right" Padding="1,1,5,1" />
                <Button Content="Delete All Orphans in View" Click="delete_all_orphans_in_view_event" HorizontalContentAlignment="Right" Padding="1,1,5,1" />
			</StackPanel>
		</StackPanel>
		<StackPanel Orientation="Horizontal" Margin="0,10,0,0" HorizontalAlignment="Right">
            <Button x:Name="previous_tag_button" Content="Previous Tag" Height="35" Click="previous_tag_event" Background="#FF89AF98" Foreground="#FF071E42" FontSize="20" BorderThickness="0,0,0,4" VerticalAlignment="Bottom" HorizontalAlignment="Left" Margin="0,0,10,0" Padding="5,1,5,1" VerticalContentAlignment="Top" >
				<Button.BorderBrush>
					<SolidColorBrush Color="#FF609274" Opacity="1"/>
				</Button.BorderBrush>
			</Button>
            <Button x:Name="next_tag_button" Content="Next Tag" Height="35" Click="next_tag_event" Background="#FF89AF98" Foreground="#FF071E42" FontSize="20" BorderThickness="0,0,0,4" VerticalAlignment="Bottom" HorizontalAlignment="Right" Padding="5,1,5,1" VerticalContentAlignment="Top" >
			</Button>
		</StackPanel>
	</StackPanel>
</Window>
Put those 3 files in a  pyRevit pushbutton and you should be good to go. I would also welcome any suggestions to improve the code.
