I am currently working on WPF data grids. I managed to create the basic form with headers, but when I began populating it with some sample data, it crashed, along with Revit.
@J.Sharma If you need specific help, provide details about your issue and a code sample, it does not have to be the whole thing, but enough for us to reproduce and understand your question
from System.Windows import Window, ResizeMode
from System.Windows.Controls import DataGrid
class SimpleUI(forms.WPFWindow):
def __init__(self, item_name, value, is_active):
self.Width = 500
self.Height = 400
self.Title = "Simple DataGrid Example"
self.ResizeMode = ResizeMode.NoResize
self.ItemName = item_name
self.Value = value
self.IsActive = is_active
self.datagrid = DataGrid()
self.Content = self.datagrid
self.populate_data()
def populate_data(self):
data = [
SimpleUI("Item 1", 100, True),
SimpleUI("Item 2", 200, False),
SimpleUI("Item 3", 300, True)
self.datagrid.ItemsSource = data
# Run the script
if __name__ == '__main__':
SimpleUI("Default Item Name", 0, False).ShowDialog()
I think you have created an infinite loop, because you are calling SimpleUI inside the populate_data.
Try:
data = [
ItemData("Item 1", 100, True),
ItemData("Item 2", 200, False),
ItemData("Item 3", 300, True)
ChatGPT in da house:
It looks like the main issue in your code stems from the way you’re initializing the SimpleUI class within its own populate_data() method, which causes an infinite recursion. When you create instances of SimpleUI inside the populate_data() method, each instance again calls populate_data(), leading to an endless loop of object creation.
You should define a separate data class (or a simple object) for the items that you’re populating in the DataGrid, instead of using the SimpleUI class itself as the data source.
Here’s a corrected version of the code:
# Define a class to represent the data for each row
class Item:
self.Value = value
self.Width = 500
self.Height = 400
# Store parameters
self.Value = value
# Initialize the DataGrid
# Populate the DataGrid with data
# Create a list of Item objects to populate the DataGrid
data = [
Item("Item 1", 100, True),
Item("Item 2", 200, False),
Item("Item 3", 300, True)
# Set the ItemsSource property of the DataGrid to the list of data
# Run the script
Changes made:
- Data Class: Created a new
Itemclass to represent each row of data in theDataGrid. - populate_data method: Replaced
SimpleUIinstances withIteminstances. - Infinite Recursion Fix: Avoided calling
SimpleUIrecursively inside its own method.
This should fix the issues with your code and properly populate the DataGrid with items.
Jean i am getting additional columns init,doc,module
I went super lazy and use chatGPT:
From the screenshot, I see that the columns have been duplicated, which likely stems from two issues:
Auto-Generated Columns: The
DataGridby default automatically generates columns for all public properties of the objects in itsItemsSource. This includes the columns that you have explicitly added insetup_columns, resulting in duplication. -
Property Names: The additional columns (
__module__,__init__) are still being shown because theDataGridis automatically generating columns for all properties of theItemclass.
To solve this, you need to disable the AutoGenerateColumns property of the DataGrid and rely only on the columns that you explicitly add.
Here’s the updated version of the code:
from System.Windows import ResizeMode
from System.Windows.Controls import DataGrid, DataGridTextColumn
from System.Windows.Data import Binding
class Item:
self.Value = value
self.Width = 500
self.Height = 400
# Store parameters
self.Value = value
self.datagrid.AutoGenerateColumns = False # Disable automatic column generation
# Configure the columns to show only the properties you want
self.setup_columns()
def setup_columns(self):
# Create and add columns for the properties you want to display
name_column = DataGridTextColumn()
name_column.Header = "Item Name"
name_column.Binding = Binding("ItemName")
self.datagrid.Columns.Add(name_column)
value_column = DataGridTextColumn()
value_column.Header = "Value"
value_column.Binding = Binding("Value")
self.datagrid.Columns.Add(value_column)
is_active_column = DataGridTextColumn()
is_active_column.Header = "Is Active"
is_active_column.Binding = Binding("IsActive")
self.datagrid.Columns.Add(is_active_column)
data = [
# Run the script
Key Fix:
- Disabling Auto-Generated Columns: Set
self.datagrid.AutoGenerateColumns = False. This prevents theDataGridfrom automatically generating columns for all public properties of theItemclass. Now, only the columns defined in thesetup_columns()method will be shown.
This should resolve the issue of duplicate columns and unnecessary internal properties showing up in the DataGrid.
