WPF Checkbox ObservableCollector
I’m trying to recreate the View/Sheet Set dialog from the print menu using WPF created in VS as shown on this great tutorial https://www.youtube.com/watch?v=fampgK0W7Nw
I’m currently trying to set which CheckBox is checked depeneding on which viewset is selected in the ComboBox. I’m having trouble sending 2 sets of data to the Checkboxes (Content and IsChecked) through the XAML structure: ItemsControl > DataTemplate > CheckBox
I’m able to get the Content passed down with
Python: self.CB1.ItemsSource = ContentName
XAML: CheckBox Content=“{Binding Path=.}”
Through some research, it seems that ObservableCollection class is used in C# to populate XAML child properties and binding. How is this done in Python?
Once I can control the IsChecked property, I should be able to modify it depending on which ViewSet is selected.
xaml file https://drive.google.com/file/d/1gDdY6oXGio3arYoljavz5QyCi8eyvZAt/view?usp=sharing
Python file: https://drive.google.com/file/d/1nZs2qfsBEWoE7GkQFsl4xNs5e-3p8GV2/view?usp=sharing
Finally got a working code! The view set editor buttons on the right side are a bit sluggish and due to the way the WPF updates by re-running FilteredElementsCollector and transactions but it works the same way the View/Sheet Set dialog for printing in Revit. I wish I knew how to enable mouse wheel scrolling on the listbox w/ checkboxes but this being the first time working with XAML, I’m satisfied with it just working. lol
Python:
clr.AddReference('System')
clr.AddReference('System.Drawing')
clr.AddReference("RevitAPI")
clr.AddReference("System.Collections")
clr.AddReference('System.Printing')
import System
from System.Printing import *
import Autodesk
import wpf
from System import Windows
from System.Drawing import *
from System.Windows.Forms import *
from pyrevit import forms, revit, DB, script, UI, framework
from System.Collections.ObjectModel import ObservableCollection
from System.ComponentModel import INotifyPropertyChanged, PropertyChangedEventArgs
from System.Windows.Input import ICommand
from System.Windows import Controls
from System import ComponentModel
import pyevent
app = __revit__.Application
xamlfile2 = script.get_bundle_file('ui2.xaml')
class Reactive(ComponentModel.INotifyPropertyChanged):
    """WPF property updator base mixin"""
    PropertyChanged, _propertyChangedCaller = pyevent.make_event()
    def add_PropertyChanged(self, value):
        self.PropertyChanged += value
    def remove_PropertyChanged(self, value):
        self.PropertyChanged -= value
    def OnPropertyChanged(self, prop_name):
        if self._propertyChangedCaller:
            args = ComponentModel.PropertyChangedEventArgs(prop_name)
            self._propertyChangedCaller(self, args)
class Command(ICommand):
    def __init__(self, execute):
        self.execute = execute
    def Execute(self, parameter):
        self.execute()
    def add_CanExecuteChanged(self, handler):
    def remove_CanExecuteChanged(self, handler):
    def CanExecute(self, parameter):
        return True
class SheetView(Reactive):
    def __int__(self, title, checks):
        NotifyPropertyChangedBase.__init__(self)
        self.Title = title
        self.Checked = checks
class viewsetInfo(Reactive):
    def __init__(self):
        self.viewSetsa = FilteredElementCollector(doc).OfClass(ViewSheetSet).WhereElementIsNotElementType().ToElements()
        self.viewSheets = FilteredElementCollector(doc).OfClass(ViewSheet)
        viewSetnames = []
        listlength = []
        for i in self.viewSetsa:
            listlength.append(i)
        self.selInd = len(listlength) - 1
            viewSetnames.append(i.Name)
        viewSheetsNames = []
        for i in self.viewSheets:
            if i.CanBePrinted:
                viewSheetsNames.append(i.Title)
        self.vsnames = viewSetnames
        self.fIndex = self.selInd
        self.viewSheetN = viewSheetsNames
        self.RviewSet = self.viewSetsa
        self.CBInfo = None
        self.CBInfoChange = None
        cbs = []
        for c, s in zip(self.SheetsList1(), self.SheetCheckList1()[self.selInd]):
            cb = Controls.CheckBox()
            cb.Content = c.Title
            cb.IsChecked = s
            # cb.IsChecked = d
            cbs.append(cb)
        self.CBInfo = cbs
    def CBInfoChange1(self, index):
        cbinfo =[]
        for c, s in zip(self.SheetsList1(), self.SheetCheckList2()[index]):
            cb.IsChecked = s
            # cb.IsChecked = d
            cbinfo.append(cb)
        self.CBInfoChange = cbinfo
    def SheetsList1(self):
        viewsheetR = []
            if i.CanBePrinted:
                viewsheetR.append(i)
        sheetlists = map(lambda c: c, viewsheetR)
        return sheetlists
    def SheetCheckList1(self):
        #viewSetsw = FilteredElementCollector(doc).OfClass(ViewSheetSet).WhereElementIsNotElementType().ToElements()
        viewsheetR = []
            if i.CanBePrinted:
        viewSetViews = []
        viewchecksets = []
        viewSetnames = []
            viewsn = []
            viewinset = []
            for e in i.Views:
                viewsn.append(e.Title)
            for s in viewSheetsNames:
                if s in viewsn:
                    viewinset.append(True)
                    viewinset.append(False)
            viewSetViews.append(viewsn)
            viewchecksets.append(viewinset)
        ischeckedlist = []
        for w in viewchecksets:
            icl = map(lambda c: c, w)
            ischeckedlist.append(icl)
        return ischeckedlist
    def SheetCheckList2(self):
        viewSetsx = FilteredElementCollector(doc).OfClass(ViewSheetSet).WhereElementIsNotElementType().ToElements()
        viewSheetx = FilteredElementCollector(doc).OfClass(ViewSheet)
        viewsheetR = []
        for i in viewSheetx:
            if i.CanBePrinted:
        viewSetViews = []
        viewchecksets = []
        viewSetnames = []
        for i in viewSetsx:
            viewsn = []
            viewinset = []
            for e in i.Views:
                if s in viewsn:
        ischeckedlist = []
class ViewsetWindow(Windows.Window, Reactive):
    sheetsSet = None
    def __init__(self):
        wpf.LoadComponent(self, xamlfile2)
        self.printManager = doc.PrintManager
        self.printManager.PrintRange = PrintRange.Select
        self.printManager.Apply()
        self.ViewSS = self.printManager.ViewSheetSetting
        self.vs = viewsetInfo()
        #self.sv = ViewModel()
        #self.CB1.ItemsSource = ObservableCollection[Name]()
        self.CB2.ItemsSource = self.vs.vsnames
        self.CB2.SelectedIndex = self.vs.fIndex
        self.CB1.ItemsSource = self.vs.CBInfo
        self.CB2.DropDownClosed += self.CBchangeEvent
    @property
    def ComboChange2(self):
        return self.CB2.SelectedItem
    @property
    def value(self):
        return self.IsChecked
    def CBchangeEvent(self, sender, args):
        self.vs2 = viewsetInfo()
        self.vsSelectedx = self.CB2.SelectedIndex
        for item, chk in zip(self.CB1.Items, self.vs2.SheetCheckList1()[self.vsSelectedx]):
            item.IsChecked = chk
    def selectAll_Click(self, sender, args):
        for item in self.CB1.Items:
            item.IsChecked = True
    def selectNone_Click(self, sender, args):
            item.IsChecked = False
    def save_Click(self, sender, args):
        vsetsel = self.CB2.SelectedItem
        for e in viewsetInfo().RviewSet:
            if e.Name == vsetsel:
                setviewcurrent = e
        ViewSS = printManager.ViewSheetSetting
        txsa = Transaction(doc)
        txsa.Start('save')
        ViewSS.CurrentViewSheetSet = setviewcurrent
        txsa.Commit()
        #txsa = Transaction(doc)
        #txsa.Start('save')
        #ViewSS.Delete()
        #txsa.Commit()
        sheet_set = DB.ViewSet()
            if item.IsChecked:
                for i in viewsetInfo().viewSheets:
                    if i.Title == item.Content:
                        sheet_set.Insert(i)
        txsaa = Transaction(doc)
        txsaa.Start('save')
        ViewSS.CurrentViewSheetSet.Views = sheet_set
        #ViewSS.SaveAs(str(vsetsel))
        ViewSS.Save()
        txsaa.Commit()
        viewsetInfo()
        vsx = viewsetInfo()
        vsx.SheetCheckList1()
        self.CB2.ItemsSource = vsx.vsnames
        newindex = self.CB2.SelectedIndex
        vsx.CBInfoChange1(newindex)
        self.CB1.ItemsSource = vsx.CBInfoChange
    def saveAs_Click(self, sender, args):
        saveasname = forms.GetValueWindow.show('Name', title='Name:', width=500, height=600)
            if item.IsChecked:
                        sheet_set.Insert(i)
                setviewcurrent = e
        txsa.Start('save')
        ViewSS.SaveAs(str(saveasname))
        txsa.Commit()
        viewsetInfo()
        vsx = viewsetInfo()
    def revert_Click(self, sender, args):
                setviewcurrent = e
        txs = Transaction(doc)
        txs.Start('rename')
        self.ViewSS.CurrentViewSheetSet = setviewcurrent
        self.ViewSS.Revert()
        txs.Commit()
        viewsetInfo()
        vsx = viewsetInfo()
        self.CB2.SelectedIndex = newindex
    def rename_Click(self, sender, args):
        rename = forms.GetValueWindow.show('Name', title='Name:', width=500, height=600)
                setviewcurrent = e
        txs.Start('rename')
        self.ViewSS.Rename(rename)
        txs.Commit()
        viewsetInfo()
        vsx = viewsetInfo()
    def delete_Click(self, sender, args):
                setviewcurrent = e
        txs.Start('rename')
        self.ViewSS.Delete()
        txs.Commit()
        newindex = self.CB2.SelectedIndex - 1
        viewsetInfo()
        vsx = viewsetInfo()
    def okay2(self, sender, args):
            if item.IsChecked:
                        sheet_set.Insert(i)
        self.returnvalue(sheet_set)
        self.Close()
        return ViewsetWindow.sheetsSet
    def cancel2(self, sender, args):
        self.Close()
XAML:
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        mc:Ignorable="d"
        Title="View/Sheet Set"
        SizeToContent="WidthAndHeight"
        Width="460.777" Height="355.111" Foreground="#FF832F2F">
    <Canvas HorizontalAlignment="Left" Height="326" VerticalAlignment="Top" Width="454" Background="#FFE6E6E6">
        <Label Content="Name:" Height="26" Canvas.Left="9" Canvas.Top="6" Width="66"/>
        <ComboBox x:Name="CB2"  Height="22" Canvas.Left="80" Canvas.Top="10" Width="237" SelectedIndex="0" SelectedItem="ComboChange2"/>
        <Button x:Name="BSave" Click="save_Click" Content="Save" Height="22" Canvas.Left="335" Canvas.Top="10" Width="106"/>
        <Button x:Name="BSaveAs" Click="saveAs_Click" Content="Save As. . ." Height="22" Canvas.Left="335" Canvas.Top="37" Width="106"/>
        <Button x:Name="BRevert" Click="revert_Click" Content="Revert" Height="22" Canvas.Left="335" Canvas.Top="64" Width="106"/>
        <Button x:Name="BRename" Click="rename_Click" Content="Rename" Height="22" Canvas.Left="335" Canvas.Top="91" Width="106"/>
        <Button x:Name="BDelete" Click="delete_Click" Content="Delete" Height="22" Canvas.Left="335" Canvas.Top="118" Width="106"/>
        <Button x:Name="BCheckAll" Content="Check All" Height="22" Canvas.Left="335" Canvas.Top="162" Width="106" Click="selectAll_Click"/>
        <Button x:Name="BCheckNone" Content="Check None" Height="22" Canvas.Left="335" Canvas.Top="189" Width="106" Click="selectNone_Click"/>
        <ScrollViewer VerticalScrollBarVisibility="Auto" HorizontalScrollBarVisibility="Auto" HorizontalAlignment="Left"
        Height="225" Width="307" Margin="0" Canvas.Left="9" Canvas.Top="51" Background="White">
            <ListBox x:Name="CB1" BorderBrush="#FF464646" Width="306">
            </ListBox>
        </ScrollViewer>
        <Button  Content="Cancel" Height="22" Canvas.Left="361" Canvas.Top="294" Width="80" Click="cancel2"/>
        <Button  Content="OK" Height="22" Canvas.Left="265" Canvas.Top="294" Width="80" Click="okay2"/>
        <Border BorderBrush="#FF707070" BorderThickness="1" Height="225" Canvas.Left="9" Canvas.Top="51" Width="307"/>
    </Canvas>
</Window>
