Hey hey,
Anyone with a bit of bandwidth to test the latest wip and ensure the last 20 or so PR actually fix the related issues?
I am running the WIP with a few of my teammates and we are both crashing when opening keynotes still.
Revit 2026
Please open a GitHub issue on the repo with all relevant details and journal files. Cc @tayOthman in the issue.
can you share the error log? also what build you are using?
@Jean-Marc
Not exactly PR.
Generate API Stubs
The “Generate API Stubs” script was recently removed. But its icons remain. If the script was removed intentionally, should the entire folder be deleted?
Good catch.
Done
THks
Not sure if this question has been asked before, but what is the compatibility between a “Machine -wide” install vs “user-install”
When a revit session starts, which will take over when both installation are present
Asking because our team will do a machine-wide install for all computers but out team usually have self-install for testing purposes
Never tried. I guess you’ll have to try and report.
