I’ve installed the WIP build to see how it plays with 2025. This is biggest reason we haven’t switched to 2025 for the office. Has anyone had issues with the keynote manager not allowing access to the keynote file if its stored on AccDocs? I just get an error that states the desktop connector is not running, but it is loaded and working.
This is something we haven’t focused on.
It requires to be able to reproduce your conditions and understands what is going on.
WA have had other bigger concerns to deal with for the compatibility with 2025.
I suggest you file an issue on the GitHub repo and document thoroughly the steps to reproduce and your setup.
No promises or eta. We are understaffed in terms of the skills level required to analyze and fix this
I was just wondering if anyone had that same issue. I realize its pretty small potatoes so to speak. I’ll see about filing a bug. Only has this issue with Revit version 2025. earlier versions of Revit seem to work just fine.
I thought I would ask if there has been any time for the keynote manager. I only get ADC not running error when using PyRevit keynote manager in 2025. All other versions of Revit are not an issue with ADC.
