What's your coding tech stack, whether it is AI backed or not, this is interesting
Answers only with typos and typed with your little finger, I 'll let you guys start:
Python, SQL, Docker, Terraform, GCP Cloud and Snowflake. Related to AI: Vertex AI, Agent2Agent protocols, Claude Code and Cortex
I started in Notepad++, then moved to pycharm. When I started coding for pyRevit I was using ChatGPT to write the first iteration, then copy+paste back and forth (this was befor any AI in IDE was a useful thing) or I did minor manual fixes.
Started using Cursor about 2-2.5years ago, and still use it. I now mainly rely on rules (both user/team and project related), docs and some skills as a harness to eliminate typical errors and improve outcome. I also use MCP (usually custom made or very project related) to some extent, but very limited.
For larger projects I first plan with ChatGPT or Claude. When Im happy with the plan I ask for a json-promt that i feed to Cursor to build the project. I give it the json-promt as a file, ask it to make some .md to reference as it builds (plans, documentation of the project and a userguide if needed). This often gives me a usable MVP in a very short time, when starting new projects.
I want to look into custom memory to see if it has benefits, just havent gotten around to testing it.
Pretty straight forward. ChatGPT Enterprise and VS Code. Every now and then, ChatGPT gets stupid and I’ll use Claude to QA/QC.
Notepad++, pyrevit forum :wink: and github copilot,
Visual Studio Code with the Claude Code extension. Using only Opus or Fable.
Python for most coding problems. I also have a simple Nuxt/Vue stack I use for web apps.
Mostly VSCode + VIM extension and CLI agents depending on the task. For recreational coding and backend I use codex, the frontend and creative tasks are delegated to claude code :rocket:
I second Notepad++. I honestly can’t be bothered with all the complicated ā€œfeaturesā€ of other IDEs. They just take too long to start up and get in the way of actually coding.
vscode + Claude Code (90% Opus / 10% Fable)
(also I rely on devloAI and coderabbit) on the repo side.
