WARNING message
WARNING [pyrevit.userconfig] Can not create config file under: C:\Users\Eric\AppData\Roaming\pyRevit\pyRevit_config.ini | File contains no section headers.
Anyone know what this means and how I can fix it?
What tools were you using?
If none, you can try and delete the config file.
Thanks for pointing me in the right direction. I was missing custom tools that I created and some others that were added in. I deleted the config file and double checked the Custom Extension Directories…I was surprised that the folders I had listed there had been removed. Not sure when that happen, but I find it curious that this warning showed up after a Autodesk Desktop Connector update.
