Rvtcad created a python code with help of ChatGPT and the Revit API which is a bit helpful for creating walls based on model lines. I am attaching images for better understanding.
Steps:
create the model line first
select the all model line
and run the code then it will work
Try this code with pyrevit or revit python shell, i used a Variable Rvtcad which you can rename it
import System
clr.AddReference('RevitAPI')
# Get the active document and start a transaction
Rvtcad = __revit__.ActiveUIDocument.Document
t = Transaction(Rvtcad, "Create Walls")
# Get the selected lines
selection = [Rvtcad.GetElement(id) for id in __revit__.ActiveUIDocument.Selection.GetElementIds()]
if not selection:
TaskDialog.Show("Error", "Please select at least one line.")
raise SystemExit
# Create the walls for each line
level = FilteredElementCollector(Rvtcad).OfClass(Level).WhereElementIsNotElementType().ToElements()
level = [l for l in level if l.Name == "Level 1"]
if not level:
TaskDialog.Show("Error", "Could not find level.")
raise SystemExit
level = level[0]
wallType = FilteredElementCollector(Rvtcad).OfClass(WallType).WhereElementIsElementType().ToElements()
wallType = [wt for wt in wallType if wt.FamilyName == "Basic Wall"]
if not wallType:
TaskDialog.Show("Error", "Could not find wall type.")
raise SystemExit
wallType = wallType[0]
for elem in selection:
if isinstance(elem, ModelCurve) and elem.GeometryCurve.GetType() == Line:
line = elem.GeometryCurve
# Create the wall
start = line.GetEndPoint(0)
end = line.GetEndPoint(1)
line = Line.CreateBound(start, end)
# Calculate the normal vector to the line
vector = line.Direction
normal = XYZ(vector.Y, -vector.X, 0)
# Set the wall location line to the exterior face of the wall
offset = wallType.Width / 2
start_offset = start + normal * offset
end_offset = end + normal * offset
line_offset = Line.CreateBound(start_offset, end_offset)
wall = Wall.Create(Rvtcad, line_offset, wallType.Id, level.Id, 10.0, 0.0, False, False)
__revit__.ActiveUIDocument.Selection.SetElementIds(List[ElementId]([wall.Id]))
except Exception as ex:
TaskDialog.Show("Error", str(ex))
# Commit the transaction
