Hi All,
Trying to run a very basic script that exports the count and name of categories used in the model. However, what I am trying to ultimately do is open a model and then run the script after it has opened. At the moment the script runs in a model before the next model is open, so if I am in an empty model it will return an empty excel sheets as there are no categories in the model. In addition hopefully do this with several models. Any help is appreciated. Thanks
from Autodesk.Revit.DB import ModelPathUtils, OpenOptions, BuiltInCategory, FilteredElementCollector, Transaction
clr.AddReference('Microsoft.Office.Interop.Excel')
from Microsoft.Office.Interop import Excel
from System import EventHandler, Uri
from Autodesk.Revit.UI.Events import ViewActivatedEventArgs, ViewActivatingEventArgs
app = __revit__.Application
uiapp = __revit__
openOptions = OpenOptions()
dir_path = os.path.dirname(os.path.realpath(__file__))
local_path = forms.pick_file(file_ext='rvt', multi_file=False)
if not local_path:
print("No file chosen!")
sys.exit()
if local_path:
if os.path.exists(local_path):
uiapp.OpenAndActivateDocument(ModelPathUtils.ConvertUserVisiblePathToModelPath(local_path), openOptions, False)
print("File does not exist: {0}".format(local_path))
categories = [BuiltInCategory.OST_GenericModel, BuiltInCategory.OST_SpecialityEquipment, BuiltInCategory.OST_Casework, BuiltInCategory.OST_Ceilings, BuiltInCategory.OST_Railings, BuiltInCategory.OST_Columns, BuiltInCategory.OST_CurtainWallMullions, BuiltInCategory.OST_Doors, BuiltInCategory.OST_Entourage, BuiltInCategory.OST_Floors, BuiltInCategory.OST_Furniture, BuiltInCategory.OST_FurnitureSystems, BuiltInCategory.OST_ElectricalCircuit, BuiltInCategory.OST_MEPSpaces, BuiltInCategory.OST_Planting, BuiltInCategory.OST_Railings, BuiltInCategory.OST_Roads, BuiltInCategory.OST_Roofs, BuiltInCategory.OST_Site, BuiltInCategory.OST_Stairs, BuiltInCategory.OST_Walls, BuiltInCategory.OST_Windows, BuiltInCategory.OST_CableTrayFitting, BuiltInCategory.OST_CableTray, BuiltInCategory.OST_CommunicationDevices, BuiltInCategory.OST_ConduitFitting, BuiltInCategory.OST_Conduit, BuiltInCategory.OST_DataDevices, BuiltInCategory.OST_DuctAccessory, BuiltInCategory.OST_DuctFitting, BuiltInCategory.OST_DuctSystem, BuiltInCategory.OST_DuctCurves, BuiltInCategory.OST_ElectricalEquipment, BuiltInCategory.OST_ElectricalFixtures, BuiltInCategory.OST_FireAlarmDevices, BuiltInCategory.OST_FlexDuctCurves, BuiltInCategory.OST_FlexPipeCurves, BuiltInCategory.OST_LightingDevices, BuiltInCategory.OST_LightingFixtures, BuiltInCategory.OST_MechanicalEquipment, BuiltInCategory.OST_PipeAccessory, BuiltInCategory.OST_PipeFitting, BuiltInCategory.OST_PipeCurves, BuiltInCategory.OST_PipingSystem, BuiltInCategory.OST_PlumbingFixtures, BuiltInCategory.OST_SecurityDevices, BuiltInCategory.OST_Sprinklers, BuiltInCategory.OST_SwitchSystem, BuiltInCategory.OST_TelephoneDevices, BuiltInCategory.OST_Wire, BuiltInCategory.OST_BoundaryConditions, BuiltInCategory.OST_RebarShape, BuiltInCategory.OST_StructuralColumns, BuiltInCategory.OST_StructuralFoundation, BuiltInCategory.OST_StructuralFraming, BuiltInCategory.OST_StructuralStiffener, BuiltInCategory.OST_StructuralTruss]
cat = []
elements = []
for i in categories:
lst = FilteredElementCollector(doc).WhereElementIsNotElementType().OfCategory(i).WhereElementIsViewIndependent().ToElements()
if len(lst) > 0:
cat.append(i.ToString()[4:])
elements.append(len(lst))
used_categories = [i for i in zip(cat, elements) if i[1] > 0]
t = Transaction(doc, "Excel Export")
# Create a new Excel Workbook
xl = Excel.ApplicationClass()
xl.Visible = True
xl.DisplayAlerts = False
workbook = xl.Workbooks.Add()
sheet = workbook.ActiveSheet
sheet.Name = "Export Categories"
# Create a header
header = ["Categories", "Count"]
for x in range(2):
sheet.Cells(1, x + 1).Value = header[x]
sheet.Cells(1, x + 1).Font.Bold = True
# Fill the rest of the cells with the data
for y in range(len(cat)):
sheet.Cells(y + 2, 1).Value = cat[y]
sheet.Cells(y + 2, 2).Value = elements[y]
# Save the file
workbook.SaveAs(r'C:\Users\helmy\Desktop\test2.xlsx')
. The cli works fine with creating the same actions however getting to have this working for multiple models is still an issue. Ill probably open another thread for it if im unable to get it working.
