from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory,Dimension
from Autodesk.Revit.Creation import Document
wallLocations = [wall.Location for wall in walls]
wallCurves = [wallLoc.Curve for wallLoc in wallLocations]
wall_line=[i for i in wallCurves]
ra=ReferenceArray()
ref=[]
for i in wallCurves:
ra.Append(i.GetEndPointReference(0))
ref.append(ra)
ra.Append(i.GetEndPointReference(1))
ref.append(ra)
for i in ref:
for b in wall_line:
dim = doc.Create.NewDimension(doc.ActiveView,b, i)
hi,
it certainly cannot run as is.
running this in pyRevit or RPS?
top of my head
doc is not defined
you can also declare the active_view, just cleaner
creation implies a revit Transaction needs to be started then commited
# what is missing at the top of your script
from pyrevit import revit
active_view = doc.ActiveView
# end of the boiler plate and imports
# what is missing at the very end, wrap your element/dimension creation
with revit.Transaction('whatever you are doing described'):
for i in ref:
for b in wall_line:
# changed to the active_view variable
dim = doc.Create.NewDimension(active_view ,b, i)
I doubt this will be enough to get it working, but that is a step in the right direction
After some changes I use the script blow and run it with Pyrevit. there is no error but also nothing happend
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory, Dimension,Transaction, Reference, ReferenceArray
from pyrevit import script, forms
from rpw import revit
uidoc = revit.uidoc
logger = script.get_logger()
wall_line = [i for i in wallCurves]
ra = ReferenceArray()
ref = []
t= Transaction(doc,"Linear Dimension")
for i in ref:
for b in wall_line:
dim = doc.Create.NewDimension(doc.ActiveView, b, i)
well, it is kind of a big mess now.
that being said. KISS rule:
from pyrevit import revit, DB
walls = DB.FilteredElementCollector(doc).OfCategory(DB.BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
with revit.Transaction("Create Dimension"):
for wall in walls:
wall_curve = wall.Location.Curve
ra = DB.ReferenceArray()
#that part does not work, to dimension walls it is slightly more complicated than that, you don't have the right number of references
ra.Append(wall_curve.GetEndPointReference(0))
ra.Append(wall_curve.GetEndPointReference(1))
dim = doc.Create.NewDimension(doc.ActiveView, wall_curve, ra)
but again, you could literally take Cyril’s example I sent you in previous forum thread
