We already have JIRA tickets submitted to the engineering team for analysis of this issue (REVIT-236376 and REVIT-237190).
Please refer to the documentation for the Revit 2023.1.8 Update. Under Issues Resolved > User Interface, you will find the note: “Fixed an issue where the Revit UI became unresponsive in some cases on Windows 11.”
For Revit 2024 and 2025, our engineering team is actively working to address this issue. However, I cannot guarantee that the fix will be included in the next release. Therefore, I recommend that you avoid making any business-critical decisions based on this issue until official confirmation is provided by Autodesk.
If the fix is released for Revit 2024 or 2025, it will be documented in the official Release Notes for those versions.
I’m not sure if I should recommend this, but Autodesk recently acquired UNIFY to do Content Catalog If you have a subscription or have some weight in the company you could push them to go for that part. The good thing is all items uploaded on content catalog auto-updates to its appropriate Revit version
ACC (Autodesk construction cloud) can also update your model in the background
but yes your method of opening model and re-saving it also works. but it mean sacrificing a computer to run the updates for a couple days
I had a similar issue with a script to upgrade multiple files.
You could try giving the UISaveAsOptions parameter.
But I think what fixed it is the part in the finally block, below.
for of in old_files:
doc = revit.open_doc(of)
doc_old_title = doc.Title
if option_replace_text: # if user option chosen to do text character replacements
doc_new_title = doc_old_title.replace(txt_search, txt_replace)
doc_new_title = "{}{}".format(prefix, doc_new_title) # Add prefix
print("{}".format(doc_new_title))
new_path_full = new_path_loc+"\\"+str(doc_new_title)+"."+filetype
doc.SaveAs(new_path_full, ui_save_opt)
finally:
doc.Close(False) # Close
# Clean-ups are to try to correct hanging when processing several files
doc.Dispose()
del doc
gc.collect() # Garbage collection
Après la fenêtre ou après le chargement du fichier avec (UIApp.Application.OpenDocumentFile), l’Api est incapable de reprendre le contrôle sur une fenêtre Modal ou non Modale, c’est fustrant….
Avec WinForms Forms.Application.DoEvents() agit à peut près correctement, seulement dans certaines circonstances.
Avec WPF Forms.Application.DoEvents() ou Dispatcher, c’est quasiment sans effet.
