I am having trouble updating my extension using the update button from the pyRevit ribbon.
My extension shows correctly in the extension manager and includes the necessary login information. When I run the updater in debug mode this is what I get:
INFO [pyrevit.versionmgr.updater] Checking internet connection...
DEBUG [pyrevit.versionmgr.updater] Url access successful: http://todoist.com/
DEBUG [pyrevit.versionmgr.updater] Fetching updates for: C:\pyRevit-Master\pyRevit\
DEBUG [pyrevit.versionmgr.updater] Fetching remote: origin of C:\pyRevit-Master\pyRevit\
DEBUG [pyrevit.coreutils.git] Making fetch options: <type 'RepoInfo' head 'b074f295861b617054c2ad1f6071bba50c885181' @ C:\pyRevit-Master\pyRevit\>
DEBUG [pyrevit.coreutils.git] Successfully pulled repo: C:\pyRevit-Master\pyRevit\
DEBUG [pyrevit.coreutils.git] New head is: b074f295861b617054c2ad1f6071bba50c885181 > Merge branch 'develop'
DEBUG [pyrevit.versionmgr.updater] Checking new commits on pyrevit repo.
DEBUG [pyrevit.versionmgr.updater] Finding installed repos...
DEBUG [pyrevit.extensions.parser] Parsing directory for extensions of type: <class 'pyrevit.extensions.components.Extension'>
DEBUG [pyrevit.extensions.parser] Searching directory: C:\Users\bschneiderhan\AppData\Roaming\pyRevit\Extensions for components of type: [<class 'pyrevit.extensions.components.Extension'>]
DEBUG [pyrevit.extensions.parser] Parsing directory for extensions of type: <class 'pyrevit.extensions.components.LibraryExtension'>
DEBUG [pyrevit.extensions.parser] Searching directory: C:\Users\bschneiderhan\AppData\Roaming\pyRevit\Extensions for components of type: [<class 'pyrevit.extensions.components.LibraryExtension'>]
DEBUG [pyrevit.extensions.parser] Searching directory: C:\pyRevit-Master\extensions for components of type: [<class 'pyrevit.extensions.components.Extension'>]
DEBUG [pyrevit.extensions.parser] Testing _get_component(s) on: C:\pyRevit-Master\extensions\ACCO.extension
DEBUG [pyrevit.extensions.parser] Testing sub_directory C:\pyRevit-Master\extensions\ACCO.extension for <class 'pyrevit.extensions.components.Extension'>
DEBUG [pyrevit.extensions.genericcomps] Icon file is: ACCO:None
DEBUG [pyrevit.extensions.genericcomps] Media file is: ACCO:None
DEBUG [pyrevit.extensions.genericcomps] Container does not have layout file defined: <type_id '.extension' name 'ACCO' @ 'C:\pyRevit-Master\extensions\ACCO.extension'>
DEBUG [pyrevit.extensions.parser] Successfuly created component: <type_id '.extension' name 'ACCO' @ 'C:\pyRevit-Master\extensions\ACCO.extension'> from: C:\pyRevit-Master\extensions\ACCO.extension
DEBUG [pyrevit.extensions.parser] Extension directory found: <type_id '.extension' name 'ACCO' @ 'C:\pyRevit-Master\extensions\ACCO.extension'>
DEBUG [pyrevit.extensions.parser] Searching directory: C:\pyRevit-Master\extensions for components of type: [<class 'pyrevit.extensions.components.LibraryExtension'>]
DEBUG [pyrevit.extensions.parser] Testing sub_directory C:\pyRevit-Master\extensions\ACCO.extension for <class 'pyrevit.extensions.components.LibraryExtension'>
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\extensions.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\extensions.json
DEBUG [pyrevit.extensions.extpackages] Looking for internal package defs under C:\pyRevit-Master\pyRevit\extensions
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitCore.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitCore.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitDevHooks.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitDevHooks.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\pyRevitDevHooks.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitDevTools.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitDevTools.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\pyRevitDevTools.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitTags.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitTags.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\pyRevitTags.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitTemplates.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitTemplates.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\pyRevitTemplates.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitTools.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitTools.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\pyRevitTools.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found extension folder pyRevitTutor.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\pyRevit\extensions\pyRevitTutor.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\pyRevit\extensions\pyRevitTutor.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Looking for C:\Users\bschneiderhan\AppData\Roaming\pyRevit\Extensions\extensions.json
DEBUG [pyrevit.extensions.extpackages] Looking for internal package defs under C:\Users\bschneiderhan\AppData\Roaming\pyRevit\Extensions
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\extensions\extensions.json
DEBUG [pyrevit.extensions.extpackages] Looking for internal package defs under C:\pyRevit-Master\extensions
DEBUG [pyrevit.extensions.extpackages] Found extension folder ACCO.extension
DEBUG [pyrevit.extensions.extpackages] Looking for C:\pyRevit-Master\extensions\ACCO.extension\extension.json
DEBUG [pyrevit.extensions.extpackages] Found C:\pyRevit-Master\extensions\ACCO.extension\extension.json
DEBUG [pyrevit.versionmgr.updater] Valid third-party extensions for update: [<type_id '.extension' name 'ACCO' @ 'C:\pyRevit-Master\extensions\ACCO.extension'>]
DEBUG [pyrevit.versionmgr.updater] List of thirdparty repos to be updated: [<type 'RepoInfo' head '3f5dcb9fadf82565fecd3cc3ece644fcc24eda17' @ C:\pyRevit-Master\extensions\ACCO.extension\>]
DEBUG [pyrevit.versionmgr.updater] Updating repo: C:\pyRevit-Master\extensions\ACCO.extension\
DEBUG [pyrevit.versionmgr.updater] Current head is: 3f5dcb9fadf82565fecd3cc3ece644fcc24eda17 > Wipe Filters
DEBUG [pyrevit.coreutils.git] Creating pull signature for username: bschneiderhan
DEBUG [pyrevit.coreutils.git] Making pull options: <type 'RepoInfo' head '3f5dcb9fadf82565fecd3cc3ece644fcc24eda17' @ C:\pyRevit-Master\extensions\ACCO.extension\>
DEBUG [pyrevit.coreutils.git] Making Credentials handler. (Username and password are available butwill not be logged for privacy purposes.)
DEBUG [pyrevit.coreutils.git] Failed git pull: C:\pyRevit-Master\extensions\ACCO.extension\ | 3 conflicts prevent checkout
DEBUG [pyrevit.versionmgr.updater] Failed updating repo: <type 'RepoInfo' head '3f5dcb9fadf82565fecd3cc3ece644fcc24eda17' @ C:\pyRevit-Master\extensions\ACCO.extension\> | 3 conflicts prevent checkout
Traceback:
File "C:\pyRevit-Master\pyRevit\pyrevitlib\pyrevit\versionmgr\updater.py", line 115, in update_repo
updated_repo_info = libgit.git_pull(repo_info)
INFO [pyrevit.versionmgr.updater] Can not update repo: ACCO.extension (Run in debug to see why)
DEBUG [pyrevit.versionmgr.updater] Updating pyrevit repo: C:\pyRevit-Master\pyRevit\
DEBUG [pyrevit.versionmgr.updater] Updating repo: C:\pyRevit-Master\pyRevit\
DEBUG [pyrevit.versionmgr.updater] Current head is: b074f295861b617054c2ad1f6071bba50c885181 > Merge branch 'develop'
DEBUG [pyrevit.coreutils.git] Making pull options: <type 'RepoInfo' head 'b074f295861b617054c2ad1f6071bba50c885181' @ C:\pyRevit-Master\pyRevit\>
DEBUG [pyrevit.versionmgr.updater] Successfully updated repo: C:\pyRevit-Master\pyRevit\
INFO [pyrevit.versionmgr.updater] :inbox_tray: Successfully updated: pyRevit to b074f29
INFO [pyrevit.versionmgr.updater] Upgrading settings...
Please let me know if more information is needed from the debugger to correct this issue. I’m not sure if it’s a GitHub issue. The extension is hosted from a private repo on GitHub.
I’ll need to manually visit each computer station to make sure it is set up via the Settings Menu in pyRevit.
