Unpin Views from Project Browser
Thought I share this script I just made. I was trying to delete views from my project browser and kept getting “Cannot delete pinned elements”. Quite annoying even though the views were not on sheets. I found this on the forums. Not sure if this is a result from also using the pyRevit “Pin All Viewports” tool.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-view-cannot-be-deleted-because-it-is-pinned.html
simply select one or more views from the Project Browser
clr.AddReference("RevitAPI")
from pyrevit import revit, script
uidoc = revit.uidoc
selection = uidoc.Selection.GetElementIds()
if not selection:
    script.show.warning("No views selected. Please select views in the Project Browser.")
    script.exit()
# Start transaction
t = Transaction(doc, "Unpin Selected Views")
unpinned = []
skipped = []
for eid in selection:
    el = doc.GetElement(eid)
    if isinstance(el, View):
            if el.Pinned:
                el.Pinned = False
                unpinned.append(el.Name)
                skipped.append(el.Name)
            skipped.append(el.Name + " (Error)")
        skipped.append(str(el))
# Report
output = script.get_output()
output.print_md("### 🔓 Unpin Results")
if unpinned:
    output.print_md("**✅ Unpinned Views:**")
    for name in unpinned:
        output.print_md("- `{}`".format(name))
    output.print_md("*No views were unpinned.*")
if skipped:
    output.print_md("\n**⚠️ Skipped or Already Unpinned:**")
    for name in skipped:
Took the liberty to make it a bit more pyrevit and less dynamo.
(untested)
from pyrevit import revit, DB, script
output.close_others(all_open_outputs=True)
def unpin_views():
    if not selection:
        return
    # Start transaction
    with revit.Transaction("Unpin Selected Views"):
        unpinned = []
        skipped = []
            el = revit.doc.GetElement(eid)
            if not isinstance(el, DB.View):
                continue
                if not el.Pinned:
                    continue
                el.Pinned = False
                # you define e but not using it?
    # Report
    if unpinned:
    if skipped:
if __name__ == "__main__":
	unpin_views()
What is
script.show.warning(). ?
I have not seen that before.
correction, should be forms.alert
