hello all,
does anyone had this problem here?
greetings kev
Hi @KevSch, welcome to the forum!
Forgive the dumb question, but… does the dynamo open up correctly when you do it manually?
Also, what is yor revit and pyrevit version? Does/did it happened on other versions, too? And maybe other computers?
Hello Andrea,
it used to work, but suddenly it stopped now for no reason. In the meantime it also doesn´t work on dynamo itself, on friday it wasn´t a problem…
revit 23 - pyrevit 2023.0.1
ok the problem is solved…
“NodeLibraryDependencies” : ,
has to be written in the code instead of “null”
greetings kev
