There is probably something in the DB module that’s overwriting a class already imported with your other imports. I would recommend not importing with the ‘*’ method of importing. Instead, you can import and assign each namespace to a variable, like this:
import System.Windows.Forms as sf
import System.Drawing as sd
This way, nothing gets overwritten. You just have to adjust your code to add the variable when you are calling a class. For example:
