from pyrevit import revit, DB, script
# Get the current document
output = script.get_output()
# Start a transaction
t = Transaction(doc, "Clear Wall Sweeps")
# Collect all walls in the document
wall_collector = FilteredElementCollector(doc) \
.OfClass(Wall) \
.WhereElementIsNotElementType() # Exclude Wall Types, only get wall instances
# Iterate through all walls
for wall in wall_collector:
# Access the wall type and compound structure
wall_type = wall.WallType
compound_structure = wall_type.GetCompoundStructure()
if compound_structure is not None:
sweeps_removed = 0 # Replace with actual logic for sweeps
output.print_md("Sweeps removed from wall: {}".format(sweeps_removed))
output.print_md("Transaction committed successfully!")
t.RollBack()
output.print_md("Error occurred: {}".format(e))
Gets the iList of wall sweeps in the wall type.
Wall..GetCompoundStructure().GetWallSweepsInfo(WallSweepType.Sweep)
Remove sweep from wall type.
CompoundStructure.RemoveWallSweep(sweep)
Removes all wall sweeps for a selected (in browser) wall type.
t = Transaction(doc, "Remove Sweeps")
selection = uidoc.Selection.GetElementIds()
for id in selection:
wtype = doc.GetElement(id)
cs = wtype.GetCompoundStructure()
wsinfo = cs.GetWallSweepsInfo(WallSweepType.Sweep)
n = 0
for s in wsinfo:
cs.RemoveWallSweep(s.WallSweepType, s.Id)
wtype.SetCompoundStructure(cs)
Removes all reveals for selected (in browswer) wall type.
type or paste code heret = Transaction(doc, "Remove Sweeps")
wsinfo = cs.GetWallSweepsInfo(WallSweepType.Reveal)
n = 0
for s in wsinfo:
