I have been trying to place the GTP point family on grid intersection points, specifically the Control Pt. I have gotten the right intersection locations but my issue is getting a transaction to work, there aren’t any errors and I have added print statements to make sure the code is actually reaching the parameters I want to set. I have gotten them to work in the past and I can’t see a problem with what I have in my code now.
This is my code as a whole, below it I will paste the actual area where I am running into my issue.
'''This tool is used for adding points on gridline intersections and if a gridline moves this tool will take care of the original GTP point and add a new one where the grid intersection moved to.\n\nAuthor: Cameron Adams'''
__title__ = 'Grid Point\nIntersection'
import csv
# Adding references
clr.AddReference('RevitAPI')
# Importing necessary modules
from getpass import getuser
import re
from pyrevit import revit, DB
from Autodesk.Revit.DB import FilteredElementCollector, FamilySymbol, Family, ViewPlan
from Autodesk.Revit.DB import ElementId, Transaction, XYZ, FamilyInstance, BuiltInCategory, Level
# Find the path of ui.xaml
xamlfile = script.get_bundle_file('ui.xaml')
# Import WPF creator and base window
import wpf
from System import Windows
from System.Windows.Controls import CheckBox
# Use the __revit__ variable provided by pyRevit to get the current application and document
uiapp = __revit__
doc = uidoc.Document
def find_pt_number():
collector = FilteredElementCollector(doc).OfClass(FamilyInstance).OfCategory(BuiltInCategory.OST_GenericModel)
lst = []
int_lst = []
for element in collector:
family = element.Symbol.Family
if family.Name == "GTP":
if element.SuperComponent:
params = element.SuperComponent.Parameters
for param in params:
if param.AsString() != '' and param.AsString() != None:
if 'PointNumber' in param.AsString():
if element.SuperComponent.LookupParameter(param.AsString()).AsString() != '':
lst.append(element.SuperComponent.LookupParameter(param.AsString()).AsString())
if element.LookupParameter('PointNumber').AsString() != '' and element.LookupParameter('PointNumber').AsString() != None:
lst.append(element.LookupParameter('PointNumber').AsString())
if len(lst) == 0:
count = 999
elif len(lst) == 1:
count = int(lst[0][-4:])
for val in lst:
int_lst.append(int(val[-4:]))
count = max(int_lst)
return count + 1
def return_minmax(val1, val2):
if val1 > val2:
maxval = val1
minval = val2
elif val2 > val1:
maxval = val2
minval = val1
print('minval and maxval and equal')
return minval, maxval
def main():
current_view = doc.ActiveView
grid_collector = FilteredElementCollector(doc).OfClass(Grid).OfCategory(BuiltInCategory.OST_Grids)
elevation = current_view.GenLevel.Elevation
y_direction = []
x_direction = []
family_name = 'GTP'
point_description = 'GRID INTERSECTION'
lst = []
for f in FilteredElementCollector(doc).OfClass(Family):
if f.Name == "GTP":
si = f.GetFamilySymbolIds()
for val in si:
lst.append(val.IntegerValue)
family_symbol = doc.GetElement(ElementId(lst[7]))
sloped_line_lst = []
boundary_x = []
boundary_y = []
line_lst = []
for val in grid_collector:
if val.Curve.GetEndPoint(0).X > val.Curve.GetEndPoint(1).X and val.Curve.GetEndPoint(0).Y != val.Curve.GetEndPoint(1).Y:
x1, y1 = val.Curve.GetEndPoint(0).X, val.Curve.GetEndPoint(0).Y
x2, y2 = val.Curve.GetEndPoint(1).X, val.Curve.GetEndPoint(1).Y
elif val.Curve.GetEndPoint(0).X < val.Curve.GetEndPoint(1).X and val.Curve.GetEndPoint(0).Y != val.Curve.GetEndPoint(1).Y:
x1, y1 = val.Curve.GetEndPoint(1).X, val.Curve.GetEndPoint(1).Y
x2, y2 = val.Curve.GetEndPoint(0).X, val.Curve.GetEndPoint(0).Y
elif val.Curve.GetEndPoint(0).X == val.Curve.GetEndPoint(1).X:
if val.Curve.GetEndPoint(0).Y > val.Curve.GetEndPoint(1).Y:
elif val.Curve.GetEndPoint(0).Y == val.Curve.GetEndPoint(1).Y:
if val.Curve.GetEndPoint(0).X > val.Curve.GetEndPoint(1).X:
line_lst.append((x1,y1,x2,y2,val.Name, val.Curve.GetEndPoint(0), val.Curve.GetEndPoint(1)))
location_lst = []
xy_lst = []
for a in line_lst:
for b in line_lst:
xy = (a,b)
slope_a = (a[3]-a[1])/(a[2]-a[0])
slope_b = (b[3]-b[1])/(b[2]-b[0])
if a != b and slope_a != slope_b:
if xy not in xy_lst and (xy[1],xy[0]) not in xy_lst:
x1,y1,x2,y2,x3,y3,x4,y4 = a[0],a[1],a[2],a[3],b[0],b[1],b[2],b[3]
numer = (x1-x3)*(y3-y4) - (y1-y3)*(x3-x4)
denom = (x1-x2)*(y3-y4) - (y1-y2)*(x3-x4)
t = numer/denom
px = x1 + t*(x2-x1)
py = y1 + t*(y2-y1)
xy_lst.append((a,b))
minx1, maxx2 = return_minmax(x1,x2)
minx3, maxx4 = return_minmax(x3,x4)
miny1, maxy2 = return_minmax(y1,y2)
miny3, maxy4 = return_minmax(y3,y4)
if minx1 <= px <= maxx2 and minx3 <= px <= maxx4 and miny1 <= py <= maxy2 and miny3 <= py <= maxy4:
location_lst.append((px,py,a[4],b[4]))
if not family_symbol.IsActive:
with Transaction(revit.doc, "activate family") as t:
family_symbol.Activate()
fixed_lst = []
temp_lst = []
for point in location_lst:
if element.Symbol.Family.Name == 'GTP':
location = element.Location.Point
temp_lst.append((location.X,location.Y))
if (point[0],point[1]) not in temp_lst:
fixed_lst.append(point)
for pos in fixed_lst:
insertion_point = XYZ(pos[0], pos[1], 0)
with Transaction(revit.doc, "place gtp point") as T:
count = find_pt_number()
T.Start()
family_instance = doc.Create.NewFamilyInstance(insertion_point, family_symbol, DB.Structure.StructuralType.NonStructural)
pt_desc = str(pos[2]) + '-' + str(pos[3]) + '_' + point_description
family_instance.LookupParameter("PointDeviationX").Set(pos[0])
family_instance.LookupParameter("PointDeviationY").Set(pos[1])
family_instance.LookupParameter("PointDeviationZ").Set(elevation)
family_instance.LookupParameter("PointDescription").Set(pt_desc)
family_instance.LookupParameter("PointRole").Set("Control Point")
family_instance.LookupParameter("PointNumber").Set('GP' + str(count))
T.Commit()
t = Transaction(doc, "delete error grid GTP points")
delete_lst = []
if family.Name == 'GTP':
if (location.X, location.Y) not in location_lst and 'GRID INTERSECTION' in element.LookupParameter("PointDescription").AsString():
delete_lst.append(element.Id)
for val in delete_lst:
doc.Delete(val)
if __name__ == "__main__":
main()
This is the area where the transaction isn’t having any errors but isn’t actually pasting a GTP point.
T.Start()
T.Commit()
