I cant figure out why revit is giving me a transaction error on the following.
I only have one transaction at the end of my code. (if i remove any reference to revit or autodesk and just print the variables instead of trying to update the parameters within revit the code works as intended.
Basically what the code is doing is grabbing an address out of a file. Grabbing the suburb and looking up a postcode and state and adding it to the text and then trying to insert it into the project address field within revit.
import csv
import time
import re
keywords = ['Unit', 'Lot', 'Villa', 'No.']
suburb = False
#this gets the appdata location from the OS
appdata = os.getenv('APPDATA')
project_info = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_ProjectInformation).ToElements()
file = open(appdata + "\LGX\programSettings.txt")
#this imports all the lines in the file to a variable
project_data_import = file.readlines()
project_number = project_data_import[5]
address = project_data_import[1][10:]
file.close()
if ',' in address:
address_1 = address.rsplit(',')
address_1[-1] = ''.join(address_1[-1].split(' ', 1))
if ' ' in address_1[-1]:
multi_suburb = True
multi_word_suburb_check = address_1[-1]
address = address.replace(',', ' ').split(' ')
multi_suburb = False
address = address.split(' ')
clean_address = []
for i in address:
if i.strip():
clean_address.append(i)
address = clean_address
address_count = len(address)
if multi_suburb == True:
suburb_check = multi_word_suburb_check
suburb_check = address[address_count - 1]
number_check = int(address[0])
except ValueError:
number_check = ''
line_4 = []
line_1 = ''
line_2 = ''
line_3 = ''
suburb_check = suburb_check.upper().rstrip('\n')
reader = csv.reader(open("C:/test/australian_postcodes.csv", 'r'))
for row in reader:
if row[2] == suburb_check:
line_4.append(row[1])
line_4.append(row[3])
line_3 = suburb_check
line_4 = ', '.join(line_4)
suburb_word_count = len(suburb_check.split(' '))
suburb = True
for x in range(suburb_word_count):
address.pop()
if suburb == False:
line_4 = ''
#print('suburb not found')
result = []
for i in keywords:
if i in address:
result.append(address.index(i))
if result != []:
line_1 = ' '.join(address[min(result):max(result) + 2])
line_2 = ' '.join(address[max(result) + 2:address_count - 1])
elif isinstance(number_check, int):
line_1 = ''.join(address[0])
line_1 = 'No. ' + line_1
line_2 = ' '.join(address[1:])
elif suburb == True:
line_1 = ' '.join(address)
address = str(line_1.upper() + "\n" + line_2.upper() + '\n' + line_3.upper() + '\n' + line_4.upper())
t = Transaction(doc, 'Fill in titleblock')
project_info.Number = project_number
project_info.Address = address
