Tab Coloring by Filter
im trying to set-up my coloring theme using filters. I have a filter called “HVAC” which is one color. I created another filter called “Navisworks Export - HVAC”, which i have chosen a different color. When i click on the tab that says “HVAC” the color is correct. When I click on the tab that says “Navisworks Export - HVAC” the color is not not correct. This tab uses the same color has the “HAVC” filter.
Has anyone else have this problem?
Thanks
