Sync View, Editing. Append(view.ViewId)
Hi all.
thanks for the platform and software
Python noob, trying to convert my dynamo scripts to pyRevit python scripts
I’ve got a tool similar to Sync views, but doesn’t run actively and can sync on a sheeted view. I feel I’ve hit wall, can anyone help or point me to a resource about views API.
# import pyrevit libraries
import os.path as op
import pickle as pl
import math
from pyrevit import framework
from pyrevit import script, revit
from pyrevit import DB, UI
from pyrevit import forms,revit,DB,script
from Autodesk.Revit.UI import
import RevitServices
uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
rect = uiview.GetZoomCorners()
for uv in uidoc.GetOpenUIViews():
	if uv.ViewId.Equals( doc.ActiveView.Id ):
		uiview = uv
for view in uidoc.GetOpenUIViews():
	if not view.ViewId.Equals( doc.ActiveView.Id ):
		view.ZoomAndCenterRectangle(rect[0], rect[1])
We are missing quite a bit of info to help you out.
I’ve managed to get it to 1 single custom node working in Dynamo (iron2.7).
I think I’m messing up on what to call library wise, pyRevit vs dynamo? and how the script exits, based on similar code by Eshan and Gavin
If anyone has any link to a post or YouTube vid roughly about this would be much appreciated
		uiview = uv
exit = []
		exit.append(view.ViewId)
OUT = exit
