Hi everyone. I am working with sun analysis tools in API and I need to set the sun position based on a specific time and date. I searched in commands and I could just found the option for defining the sun position based on the frame number. Is there any command for setting the sun position based on time and date?
and finally, In this method, I can get the sun direction for each day and time
def SunDirection ():
t=Transaction(doc, “Assigning the values”)
j=datetime.datetime.now()
Dt_kind=System.DateTimeKind.Local
specTime=System.DateTime.SpecifyKind(j,Dt_kind)
settings=view.SunAndShadowSettings
settings.SunAndShadowType = SunAndShadowType.StillImage
uidoc.RefreshActiveView()
doc.Regenerate()
e=settings.GetFrameAzimuth(settings.ActiveFrame)
print(specTime)
print(e180/(math.pi))
return specTime, e180/(math.pi)
I have written this function to get the sun Azimuth. the only problem is that the sun position does not update based on the given date and time and gets this info from the sun setting pannel in Revit. does anybody know the sun position can be updated?
@mhmesh
I did not look to much into it but the code I did might help you to get there
There is an issue, probably a know one, with the sun (physical geometry in the trajectory) that does not update in terms of location if you don’t ‘touch’ it. The trick I use is to set a parameter to a certain value in another transaction and then set it back to its previous value.
clr.AddReference('System')
import System
from pyrevit import DB, revit, script, HOST_APP
output = script.get_output()
# Close other output when launched several times
close_other_output = output.close_others(all_open_outputs=True)
view = doc.ActiveView
uidoc = HOST_APP.uidoc
DT = System.DateTime.Now
with revit.Transaction ('Set sun Date and Time to Now'):
settings_sun = view.SunAndShadowSettings
settings_sun.StartDateAndTime = DT
# or settings_sun.EndDateAndTime = DT
# Make newly created view active
uidoc.RequestViewChange(view)
# Maybe overkill
doc.Regenerate()
with revit.Transaction ('Touch and Go'):
# as the physical sun does not seem to move even though the parameters are really passed through, a touch and go is mandatory to refresh its position in the active view
sun_path_size = settings_sun.get_Parameter(DB.BuiltInParameter.VIEW_GRAPH_SUN_PATH_SIZE).AsInteger()
temp_sun_path_size = sun_path_size
param = settings_sun.Parameter[DB.BuiltInParameter.VIEW_GRAPH_SUN_PATH_SIZE]
param.Set(10)
param.Set(temp_sun_path_size)
print (view.Name)
print (DT)
print (param.AsInteger())
I hope that helped a bit
Sorry for my late reply. it is great and working as I expected. thank you so much
