Hello pyRevit users and developers,
I was wondering if it is possible to run a RhinoEtoform Python File as a Button inside PyRevit. Or Use Pyrevit button to load Rhino exe
I appreciate any resources or suggestions
Best,
Abhishek S
Best,
Abhishek S
this might help
Thanks a lot for this ! I appreciate this a lot!
Hello @revitislife ,
I tried the GitHub solution and also added pyrevit to my Environmental variables to my PATH .
I am unable to use “RhinoCommon” inside clr
The error image screeshot for the same is as below :
make sure you have rhino.inside running inside Revit before you execute the code
