Subfolders in lib
Hi all,
i’m am wondering how i can work with subfolder in de Lib folder of an extension.
When i put my .py module inside a subfolder of the lib, pyrevit doesn’t seen to find it once I want to run the script.
In visual studio the linting does work.
below some screenshots of the code and file structure:
from Selection.Sheets import *
this is the error i get:
 File "C:\Users\AlexanderV\AppData\Roaming\pyRevit\Extensions\BBpy.extension\BBpy.tab\Test.panel\ViewsStructure.Pushbutton\script.py", line 22, in <module>
ImportError: No module named Selection.Sheets
IronPython.Runtime.Exceptions.ImportException: No module named Selection.Sheets
 at Microsoft.Scripting.Runtime.LightExceptions.ThrowException(LightException lightEx)
 at Microsoft.Scripting.Runtime.LightExceptions.CheckAndThrow(Object value)
 at IronPython.Runtime.Operations.PythonOps.ImportStar(CodeContext context, String fullName, Int32 level)
 at Microsoft.Scripting.Interpreter.ActionCallInstruction`3.Run(InterpretedFrame frame)
thx for the feedback!
Found the error.
There should be an init.py int he lib-folders and every subdirectorie
