SSG extension - material to csv error
Need help resolving the an error when using the
“Material to CSV tool”
It returns the following error:
 File "C:\Users\studi\AppData\Roaming\pyRevit\Extensions\pySSG.extension\pySSG.tab\Materials.Panel\Create.pulldown\Materials to CSV.pushbutton\script.py", line 225, in <module>
TypeError: expected int, got str
Microsoft.Scripting.ArgumentTypeException: expected int, got str
Pinging @kbruxvoort here since he’s the author of the extension :wink:
As a matter of fact, there’s already an open issue on his github
Thanks for bringing my attention to this @sanzoghenzo.
@ivanzep, I haven’t had much time to update the extension recently. I will look into it and handle the issue in github.
Thank you really appreciate it, It is a great tool! Looking forward to it
