I want to develop a tool for Show unconnected beams and overlapped beams in python. Anybody have an idea
@Mathupathy
Welcome.
Did you coding something? Can you share it? What step are you blocked?
clr.AddReference('RevitAPI')
# Get all columns in the document
columns = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralColumns).OfClass(FamilyInstance).ToElements()
# Loop through the columns and check if they are joined
for column in columns:
location = column.Location
if isinstance(location, LocationPoint):
point = location.Point
for ref in column.GetReferences(FamilyInstanceReferenceType.StrongReference):
element = doc.GetElement(ref)
if isinstance(element, FamilyInstance):
if element.Location.Point.DistanceTo(point) < doc.Application.ShortCurveTolerance:
# Column is joined, skip to the next one
break
# Column is not joined, set Structural Usage to "Unused"
parameter = column.get_Parameter(BuiltInParameter.ELEM_CATEGORY_PARAM)
if parameter:
if parameter.AsValueString() == "Structural Columns":
parameter = column.get_Parameter(BuiltInParameter.STRUCTURAL_USAGE_NOT_ANALYZED)
if parameter:
parameter.Set(1)
