For those looking for the solution to this problem i solved it with the code below.
the clue is in the fact that u don’t need to use BoudanryCurves (wich sounds logical) but the SketchId.
Then retrieve the profile from the sketch.
this code was for testing purposes in dynamo but also aplies in python(pyrevit):
# Load the Python Standard and DesignScript Libraries
clr.AddReference("RevitAPI")
import Autodesk
from Autodesk.Revit.DB import *
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
import Autodesk.DesignScript.Geometry as DS
import Revit
clr.ImportExtensions(Revit.GeometryConversion)
link = IN[0]
shafts = FilteredElementCollector(link).OfCategory(BuiltInCategory.OST_ShaftOpening).ToElements()
# Place your code below this line
shaft_curves =[]
for shaft in shafts:
sketch = link.GetElement(shaft.SketchId)
profile = sketch.Profile
curves = []
for profile_curve in profile:
for curve in profile_curve:
curves.append(curve.ToProtoType())
shaft_curves.append(curves)
# Assign your output to the OUT variable.
OUT = shaft_curves
