Set Gird and Level From 3D to 2D make Revit Crash
import time  # Importing time module for delays
clr.AddReference("System")
from pyrevit.forms import ProgressBar
logger = script.get_logger()
output = script.get_output()
allowed_view_types = [ViewType.AreaPlan, ViewType.CeilingPlan, ViewType.EngineeringPlan, ViewType.FloorPlan]
all_grids = FilteredElementCollector(doc).OfClass(Grid).WhereElementIsNotElementType().ToElements()
datum_extent_types = list(clr.GetClrType(DatumExtentType).GetEnumValues())
# Correctly defined filter function
def filter_views(view):
    return view.ViewType in allowed_view_types
# UI Froms Alerts
res = forms.alert("Warning: This script may cause Revit to crash. "
                  "It is highly recommended that you Synchronize your model or Save your file.\n"
                  "Are you sure you want to run the script?",
                  options=["Run Script", "Exit"])
# UI Select View
if res == "Run Script":
    selected_views = forms.select_views(title='Select Levels',
                                     button_name='Select',
                                     multiple=True,
                                     filterfunc=filter_views,
                                     doc=None,
                                     use_selection=False)
    script.exit()
# Main Function
if selected_views:
    max_value = len(selected_views)  # Set max_value based on the number of selected views
    with ProgressBar(title="Processing Views", cancellable=True) as pb:
        with Transaction(doc, __title__) as t:
            success_count = 0
            data = []
                for counter, view in enumerate(selected_views):  # Enumerate through selected views
                    if pb.cancelled:
                        break
                    view_success = False
                    for grid in all_grids:
                            grid.SetDatumExtentType(DatumEnds.End0, view, datum_extent_types[1])
                            grid.SetDatumExtentType(DatumEnds.End1, view, datum_extent_types[1])
                            view_success = True
                            if "The datum plane cannot be visible in the view." in str(e):
                                continue
                    if view_success:
                        success_count += 1
                        data.append([view.ViewType, view.Name, 'TRUE', output.linkify(view.Id)])
                        data.append([view.ViewType, view.Name, 'FALSE', output.linkify(view.Id)])
                    # Update the progress bar with the current progress
                    pb.update_progress(counter + 1, max_value)
                logger.error("Unexpected error: {}".format(str(e)))
            finally:
                data.sort(key=lambda x: x[2], reverse=False)
                output.print_table(
                    table_data=data,
                    title="Set Grid to 2D",
                    columns=["View Type", "View Name", "Set Grid 2D", "OwnerView"],
                    formats=['', '', '', '']
In my script, it’s very straightforward: simply select ‘view’ and then run the script. However, several of my scripts cause Revit to crash.
Hi, I didn’t read your code carefully, but you can review my code below:
from System.Collections.Generic import *
from rpw.ui.forms import Alert
clr.AddReference('RevitAPI')
import Autodesk
view = doc.ActiveView
app = __revit__.Application
DB = Autodesk.Revit.DB
# ----------------------------START CODE------------------------------
    # ----------------------------Select Template Sheet------------------------------
    grid_activeview = FilteredElementCollector(doc, view.Id).OfClass(Grid).WhereElementIsNotElementType().ToElements()
    selected_option = forms.CommandSwitchWindow.show(
        ['3D to 2D', '2D to 3D'],
        message='Select Option:', )
    # ----------------------------TRANSACTION------------------------------
    if not selected_option:
        sys.exit()
    if selected_option == '3D to 2D':
        t = Transaction(doc, 'Convert Grids')
        for i in grid_activeview:
            i.SetDatumExtentType(DatumEnds.End0, view, DatumExtentType.ViewSpecific)
            i.SetDatumExtentType(DatumEnds.End1, view, DatumExtentType.ViewSpecific)
    if selected_option == '2D to 3D':
            i.SetDatumExtentType(DatumEnds.End0, view, DatumExtentType.Model)
            i.SetDatumExtentType(DatumEnds.End1, view, DatumExtentType.Model)
    Alert('Convert Grids Sucessfully', 'Transaction Done')
except Autodesk.Revit.Exceptions.OperationCanceledException:
except Exception as ex:
    TaskDialog.Show("Error", "Warning: {}".format(ex))
