Set Default Line Style
I’m tryin to create a script that starts the detail line command with a specific line style type set. The way I was thinking of doing this is by changing the default type of the detail line command. I can’t figure out how to do this with detail lines. I’ve seen post about other type of elements but I can’t seem to find the exact thing I need for this. For example I’m not sure that there is a ElementTypeGroup for lines.
Here is what I have so far, be warned, this has a lot of test code and hashed out code in it:
# Oneline Diagram
# Import libraries
from pyrevit import DB, revit, script, forms, output, UI
from Autodesk.Revit.UI import UIDocument
from Autodesk.Revit.DB.Electrical import ElectricalSystem
# FilteredElementCollector,
# RevitLinkInstance,
# GeometryInstance)
# Current document
cView = doc.ActiveView
#document = doc.Document
# Debug toggles
globalDebug = True
disabledScript = False
def dprint(*printItems):
    if globalDebug:
        for pI in printItems:
            print(pI)
# Variables
output = output.get_output()
# Collector
# Line Styles
line_styles = (FilteredElementCollector(doc).
               WherePasses(ElementClassFilter(GraphicsStyle)))
dprint(line_styles)
line_style_demo = None
for l in line_styles:
    if l.Name == ".SD-Det-Hidden-5":
                line_style_demo = l
dprint(line_style_demo)
dprint(line_style_demo.Name)
dprint("Graphics Id")
dprint(line_style_demo.Id)
dprint("Graphic Style Category")
line_style_cat = line_style_demo.GraphicsStyleCategory
dprint(line_style_cat.Name)
dprint(line_style_cat.Id)
dprint("Graphics Style Type")
line_style_type_id = line_style_demo.GetTypeId
dprint(line_style_type_id)
dprint("Get Type Id")
line_style_type = line_style_demo.GraphicsStyleType
dprint(line_style_type)
# Family Category
#cats = FilteredElementCollector(doc).OfClass()
# .FamilyCategoryId
# cat_id = line_style_demo.GraphicsStyleCategory.Id
# dprint(cat_id)
current = doc.GetDefaultElementTypeId(ElementTypeGroup.TextNoteType)
dprint("Current : ")
dprint(current)
#script.exit()
# Main Run
t = Transaction(doc, "pyRevit - Detail Line Demo")
doc.SetDefaultElementTypeId(ElementTypeGroup.DetailGroupType, line_style_demo.Id)
#doc.SetDefaultFamilyTypeId(cat_id, line_style_demo.GroupId)
give this a shot and see if you can take anything away from it. small note, i was never able to get it to set the line type prior to activating the detail postable command. so it creates a small line to then set the linetype.
something i made a while back for one line diagrams.
"""Starts Revit's native Detail Line workflow using a saved default line style.
NORMAL RUN:
1. Loads the saved default line style from pick_config.py.
2. Finds the matching Revit Lines subcategory.
3. Looks for an existing detail line in the active view using that line style.
4. If no matching detail line exists, creates a tiny seed detail line using the saved line style.
5. Selects that line.
6. Posts Revit's native Create Similar command.
SHIFT-CLICK CONFIGURATION:
1. Lists all loaded line styles under the Revit Lines category.
2. User selects one default line style.
3. The selected style name is saved to pyRevit config through pick_config.py.
Why Create Similar:
- Revit does not expose a reliable public API for directly setting the active native Detail Line line style.
- Create Similar from a detail line is the most reliable way to launch the native Detail Line command with the desired style.
import traceback
clr.AddReference("RevitAPI")
    BuiltInCategory,
    CurveElement,
    DetailCurve,
    ElementId,
    GraphicsStyleType,
    Line,
    Transaction,
    View,
    ViewType,
    XYZ
from Autodesk.Revit.UI import (
    PostableCommand,
    RevitCommandId
from pyrevit import revit, forms, script, EXEC_PARAMS
import pick_config
uidoc = revit.uidoc
uiapp = uidoc.Application
output = script.get_output()
# BASIC HELPERS
def safe_str(value):
        if value is None:
            return ""
        return str(value)
        return ""
def get_id_int(element_id):
        return element_id.IntegerValue
            return int(element_id)
            return -1
# VIEW HELPERS
def is_supported_detail_line_view(view):
    if not view:
        return False
        if view.IsTemplate:
            return False
        view_type = view.ViewType
        return False
    supported_view_types = [
        ViewType.FloorPlan,
        ViewType.CeilingPlan,
        ViewType.EngineeringPlan,
        ViewType.AreaPlan,
        ViewType.Section,
        ViewType.Elevation,
        ViewType.Detail,
        ViewType.DraftingView,
        ViewType.Legend
    return view_type in supported_view_types
def get_active_view_center_point(view):
    Returns a reasonable point in the active view for creating the seed line.
    For most views, Origin works fine.
    If CropBox exists, use the crop box center.
        crop = view.CropBox
        if crop:
            min_pt = crop.Min
            max_pt = crop.Max
            x = (min_pt.X + max_pt.X) / 2.0
            y = (min_pt.Y + max_pt.Y) / 2.0
            z = (min_pt.Z + max_pt.Z) / 2.0
            center = XYZ(x, y, z)
                trf = crop.Transform
                center = trf.OfPoint(center)
            return center
        return view.Origin
        return XYZ(0, 0, 0)
def get_view_right_direction(view):
        right = view.RightDirection
        if right:
            return right
    return XYZ(1, 0, 0)
# LINE STYLE HELPERS
def get_lines_category():
        return doc.Settings.Categories.get_Item(BuiltInCategory.OST_Lines)
        return None
def get_line_style_category_by_name(line_style_name):
    line_style_name = safe_str(line_style_name).strip()
    if not line_style_name:
        return None
    lines_cat = get_lines_category()
    if not lines_cat:
        return None
        subcats = lines_cat.SubCategories
        return None
    for subcat in subcats:
            if safe_str(subcat.Name).strip() == line_style_name:
                return subcat
    return None
def get_projection_graphics_style(line_style_category):
    if not line_style_category:
        return None
        return line_style_category.GetGraphicsStyle(GraphicsStyleType.Projection)
        return None
def get_curve_line_style_name(curve_element):
        style = curve_element.LineStyle
        if style:
            return safe_str(style.Name).strip()
    return ""
# FIND OR CREATE SEED DETAIL LINE
def find_existing_detail_line_in_active_view(view, line_style_name):
    Find an existing detail line in the active view that already uses the desired style.
    This avoids creating a new seed line when possible.
        return None
    collector = FilteredElementCollector(doc, view.Id) \
        .OfCategory(BuiltInCategory.OST_Lines) \
        .WhereElementIsNotElementType()
    candidates = []
    for el in collector:
            if not isinstance(el, CurveElement):
                continue
            continue
            if get_curve_line_style_name(el) == line_style_name:
                candidates.append(el)
    if not candidates:
        return None
    candidates = sorted(candidates, key=lambda x: get_id_int(x.Id))
    return candidates[0]
def create_seed_detail_line(view, line_style_category):
    Creates a small detail line in the active view and assigns the desired style.
    Note:
    This seed line is intentionally left in the view because Revit needs a selected
    source element for Create Similar.
    gs = get_projection_graphics_style(line_style_category)
    if not gs:
        return None
    center = get_active_view_center_point(view)
    right = get_view_right_direction(view)
    # Revit will reject curves shorter than Application.ShortCurveTolerance.
    # Use something safely above the tolerance.
        min_len = doc.Application.ShortCurveTolerance
        min_len = 0.01
    # Use at least 1 inch, or 10x Revit's short curve tolerance.
    one_inch = 1.0 / 12.0
    seed_length = max(one_inch, min_len * 10.0)
    p1 = center
    p2 = center.Add(right.Multiply(seed_length))
    line = Line.CreateBound(p1, p2)
    new_curve = None
    with Transaction(doc, "NXGN - Create Detail Line Style Seed") as t:
        new_curve = doc.Create.NewDetailCurve(view, line)
            new_curve.LineStyle = gs
    return new_curve
def get_or_create_source_detail_line(view, line_style_name, line_style_category):
    existing = find_existing_detail_line_in_active_view(view, line_style_name)
    if existing:
        return existing, False
    created = create_seed_detail_line(view, line_style_category)
    return created, True
# SELECTION / COMMAND HELPERS
def set_single_selection(element):
    ids = List[ElementId]()
        ids.Add(element.Id)
    uidoc.Selection.SetElementIds(ids)
def post_create_similar_command():
        cmd_id = RevitCommandId.LookupPostableCommandId(PostableCommand.CreateSimilar)
    except Exception as ex:
        forms.alert(
            "Could not find Revit's Create Similar command.\n\n{0}".format(ex),
            exitscript=True
    if not cmd_id:
        forms.alert(
            "Could not find Revit's Create Similar command.",
            exitscript=True
        can_post = uiapp.CanPostCommand(cmd_id)
        can_post = True
    if not can_post:
        forms.alert(
            "Revit cannot start Create Similar right now.\n\n"
            "Try again from a plan, section, elevation, drafting view, detail view, or legend.",
            exitscript=True
        uiapp.PostCommand(cmd_id)
        forms.alert(
            "Failed to start Revit's Create Similar command.\n\n{0}".format(ex),
            exitscript=True
# NORMAL RUN
def run_normal():
    view = doc.ActiveView
    if not is_supported_detail_line_view(view):
        forms.alert(
            "Detail Lines cannot be started from the current active view.\n\n"
            "Active View: {0}\n"
            "View Type: {1}".format(view.Name, view.ViewType),
            exitscript=True
    line_style_name = pick_config.get_default_line_style_name_or_configure()
        forms.alert(
            "No default line style was selected.",
            exitscript=True
    line_style_category = get_line_style_category_by_name(line_style_name)
        forms.alert(
            "The saved default line style was not found in this project:\n\n{0}\n\n"
            "Shift-click the tool to choose a new default.".format(line_style_name),
            exitscript=True
    source_line, was_created = get_or_create_source_detail_line(
        view,
        line_style_name,
        line_style_category
    if not source_line:
        forms.alert(
            "Could not find or create a source detail line for this line style:\n\n{0}".format(line_style_name),
            exitscript=True
    set_single_selection(source_line)
    if was_created:
        output.close_others()
        output.print_md("# NXGN | Detail Line By Style")
        output.print_md("")
        output.print_md("## Seed Detail Line Created")
        output.print_md("")
        output.print_md("A tiny source detail line was created because no existing detail line in the active view used the saved style.")
        output.print_md("")
        output.print_md("| Field | Value |")
        output.print_md("|---|---|")
        output.print_md("| Saved Line Style | {0} |".format(line_style_name))
        output.print_md("| Seed Detail Line | {0} |".format(output.linkify(source_line.Id)))
        output.print_md("")
        output.print_md("This seed line is used only so Revit can run **Create Similar** with the correct line style.")
# ENTRY
if __name__ == "__main__":
        if EXEC_PARAMS.config_mode:
            pick_config.configure_default()
            run_normal()
        output.print_md("")
        output.print_md("## Error")
        output.print_md("")
        output.print_md("```")
        output.print_md(str(ex))
        traceback.print_exc()
"""Default Detail Line Style configuration for NXGN | Detail Line By Style.
SHIFT-CLICK:
- Lists all loaded line styles under the Revit "Lines" category.
- User selects one default line style.
- Saved default becomes the line style used when the normal tool is run.
NORMAL RUN:
- Loads the saved default line style name.
- If no default exists, prompts user to configure one.
from pyrevit import revit, DB
my_config = script.get_config("NXGN_DefaultDetailLineStyle")
KEY_DEFAULT_LINE_STYLE_NAME = "default_detail_line_style_name"
# BASIC HELPERS
        if value is None:
            return ""
        return str(value)
        return ""
def get_line_style_name_from_option(option):
        return option.line_style_name
        return option.name
        return str(option)
        return ""
# LIST ITEM
class LineStyleItem(forms.TemplateListItem):
    def __init__(self, line_style_name, checked=False):
        forms.TemplateListItem.__init__(self, line_style_name, checked=checked)
        self.line_style_name = line_style_name
    @property
    def name(self):
        return self.line_style_name
# CONFIG LOAD / SAVE
def load_config():
    saved = my_config.get_option(KEY_DEFAULT_LINE_STYLE_NAME, "")
    return safe_str(saved).strip()
def save_config(line_style_name):
    setattr(my_config, KEY_DEFAULT_LINE_STYLE_NAME, line_style_name)
    script.save_config()
# LINE STYLE COLLECTION
        return revit.doc.Settings.Categories.get_Item(DB.BuiltInCategory.OST_Lines)
        return None
def collect_line_style_names():
    line_style_names = []
    if not lines_cat:
        return line_style_names
            name = safe_str(subcat.Name).strip()
            if name and name not in line_style_names:
                line_style_names.append(name)
    return sorted(line_style_names, key=lambda x: x.lower())
def line_style_exists(line_style_name):
        return False
    return line_style_name in collect_line_style_names()
# SHARED PICKER
def pick_line_style(title, button_name, prechecked_line_style_name):
    line_style_names = collect_line_style_names()
    if not line_style_names:
        forms.alert(
            "No line styles were found under the Revit Lines category.",
            exitscript=True
    prechecked_line_style_name = safe_str(prechecked_line_style_name).strip()
    options = []
    for name in line_style_names:
        checked = name == prechecked_line_style_name
        options.append(LineStyleItem(name, checked=checked))
    selected = forms.SelectFromList.show(
        options,
        title=title,
        button_name=button_name,
        multiselect=False
    if selected is None:
        script.exit()
    selected_name = get_line_style_name_from_option(selected)
    selected_name = safe_str(selected_name).strip()
    if not selected_name:
        script.exit()
    return selected_name
# SHIFT-CLICK CONFIG UI
def configure_default():
    previous_name = load_config()
    selected_name = pick_line_style(
        title="NXGN | Default Detail Line Style",
        button_name="Save Default",
        prechecked_line_style_name=previous_name
    save_config(selected_name)
    output.print_md("# NXGN | Default Detail Line Style")
    output.print_md("")
    output.print_md("## Default Line Style Saved")
    output.print_md("")
    output.print_md("| Setting | Value |")
    output.print_md("| Default Detail Line Style | {0} |".format(selected_name))
# NORMAL-RUN LOAD
def get_default_line_style_name_or_configure():
    saved_name = load_config()
    if saved_name and line_style_exists(saved_name):
        return saved_name
    if saved_name and not line_style_exists(saved_name):
        forms.alert(
            "Please select a new default.".format(saved_name)
    return configure_default()
    configure_default()
Thanks for the suggestion. Pretty funny, I’m guessing I might have to resort to the same thing. Ill wait a day or two and see if I can set it properly but I might try this in the mean time.
Why do you have a try statement for setting up the post command for create similar? Is it sometimes not available?
This is one of the very first tools i made like 2 years ago. so i don’t recall what i did and why i did it other than “it’s working, i’ll leave it alone”:sweat_smile:
Obviously not done with this yet, but I can figure out why it is not starting the create similar command. I’ve tried two methods of getting the command id. There is no error. It just runs and nothing happens.
# Oneline Diagram
# Import libraries
from Autodesk.Revit.UI import UIDocument, PostableCommand
from Autodesk.Revit.UI.Selection import Selection
# GeometryInstance)
# Current document
# Debug toggles
globalDebug = True
    if globalDebug:
            print(pI)
# Variables
collected_lines = (FilteredElementCollector(doc).
                   OfCategory((BuiltInCategory.OST_Lines)).
                   WhereElementIsNotElementType().
                   ToElements())
example_line = None
for cl in collected_lines:
    line_style_name = cl.LineStyle.Name
    dprint(line_style_name)
    if line_style_name == ".SD-Det-Hidden-5":
        example_line = cl
        break
collection = List[ElementId](example_line.Id.Value)
dprint("example Line:")
dprint(example_line)
if example_line:
    selection = uidoc.Selection
    selection.SetElementIds(collection)
    # command_id = UI.RevitCommandId.LookupPostableCommandId(PostableCommand.CreateSimilar)
    command_id = UI.RevitCommandId.LookupCommandId('ID_EDIT_CREATE_SIMILAR')
    dprint(command_id)
    UI.UIApplication(doc.Application).PostCommand(command_id)
Have time to circle back around to this. Anyone know why the script doesn’t do anything?
Edit 1:
Just tried testing another command and it did work:
dprint("lookupPostable method:")
cmd_id = RevitCommandId.LookupPostableCommandId(PostableCommand.Align)
dprint(cmd_id)
dprint(cmd_id.Name)
I was thinking maybe it something wrong with the selection, but there is no noise notification like when you manual start the create similar command without anything selected.
Edit 2:
Ok so now I tested running the script with this and just manually selected a line before running the script and didn’t include any of the selection stuff and it started the command when I had the line selected. It did not start the command when I had nothing selected and it did not do the audio warning. So I think PostCommand doesn’t que the audio. This makes me thing something is wrong with the selection part of the script.
dprint(cmd_id)
dprint(cmd_id.Name)
script.exit()
Edit 3:
Got it working and it was the selection. Managed to get it working by removing the .value on the elementid, which I thought I needed at some point because I had errors without it but I can’t rememeber what exactly.
