I can´t find any information about setting the default types for dimensions, spot elevations, …
Is this possible with the API? A workaround would be to place and delete a dimension because this seems to set the default type.
I can not get it to work with SetDefaultFamilyTypeId:
collector = FilteredElementCollector(doc).OfClass(Autodesk.Revit.DB.DimensionType)
for symbol in collector:
if symbol.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString() == "XXX":
new_spot_elevation_symbol = symbol
break
dimension_category_id = ElementId(BuiltInCategory.OST_Dimensions)
doc.SetDefaultFamilyTypeId(dimension_category_id, new_spot_elevation_symbol.Id)
Exception: The family type id familyTypeId is invalid for the give family category familyCategoryId.
Parameter name: familyTypeId
It is necessary to test the type suitability to be a default family type, for not every type can be set as default.
Trying to set a non-qualifying default type will cause an exception
from pyrevit import revit
defaultTypeId = # element type group
typeId = # element Id of the type you want to set as default
doc.SetDefaultElementTypeId(defaultTypeId, typeId)
from pyrevit import revit, DB
dim_type_group = DB.ElementTypeGroup.SpotElevationType
p = DB.BuiltInParameter.ALL_MODEL_TYPE_NAME
new_dim_type = [dt for dt in DB.FilteredElementCollector(doc).OfClass(DB.DimensionType) if dt.get_Parameter(p).AsString() == 'EFP Höhe (Absolut)'][0]
with revit.Transaction('Set default dimension type'):
doc.SetDefaultElementTypeId(dim_type_group, new_dim_type.Id)
