I’ve noticed in the last month that there are times this forum is blocked by my company’s security with the reason being the security certificate is expired or expiring soon. Is this something that can be fixed? I’ve previously been able to access the forum with no problem but the expiring certificate is preventing me now.
Haven’t noticed.
I’ll check with the host
Reply from the host
Emma replied to your support request, #625541 with the following response:
We did not have any issues with the certificate (if we did, we would have told you).
The current certificate is valid from Tue, 13 Oct 2026 09:06:57 GMT until Mon, 11 Jan 2027 09:06:56 GMT
I suspect this is something within the network of the user. Recommendation is to disable wifi and check on their phone, or try at home on another PC, then you can rule out both the network and the device at once.
