Scripts per Revit Version
Is it possible to use different scripts for different versions of Revit using the bundle context in the same button? Ideally something like this:
I’d probably sort it out in the script itself if it was me.
from pyrevit import HOST_APP
version = HOST_APP.version
It would have the added benefit of you not needing to repeat work as much of the scripts, I assume, would be the same.
It is handled like @Archibum mentioned in most pyrevit modules and also in the print sheets tool
Thanks yeah I’m really looking for a lazy way to avoid multiple updates to individual python nodes within Dynamo scripts. If there could be two dyn files referenced it would save a lot of time between versions, and maintain working scripts for previous versions in the interim
@eprunty So something like the tool configs in the bundle.yaml file? See if this works for you. Look under “Supported Revit Versions”
Thanks Ehsan, that’s exactly it
