Hello, whenerver I run the functions script.data_exitst(“example”), script.store_data(“example”, dataClass) or script.load_data(“example”) after a transaction, I get below error.
To reproduce this issue you can simply run bellow code:
from pyrevit import revit
49 with revit.Transaction("test"):
50 pass
51 print script.data_exists("example")
If you run this code without a transaction or in the transaction, there is no issue.
For my use case, it is not possible to run these functions inside a transaction.
**IronPython Traceback:**
File "C:\Users\Wietse_d\Documents\Github\WDE-addins\WYC-addins.extension\WYC.tab\Dev.panel\Test.pushbutton\script.py", line 51, in <module>
File "C:\Users\Wietse_d\AppData\Roaming\pyRevit\pyRevit\master\pyrevitlib\pyrevit\script.py", line 743, in data_exists
File "C:\Users\Wietse_d\AppData\Roaming\pyRevit\pyRevit\master\pyrevitlib\pyrevit\script.py", line 315, in get_document_data_file
File "C:\Users\Wietse_d\AppData\Roaming\pyRevit\pyRevit\master\pyrevitlib\pyrevit\revit\db\__init__.py", line 297, in filename
File "C:\Users\Wietse_d\AppData\Roaming\pyRevit\pyRevit\master\pyrevitlib\pyrevit\revit\db\__init__.py", line 293, in path
AttributeError: 'NoneType' object has no attribute 'PathName'
**Script Executor Traceback:**
System.MissingMemberException: 'NoneType' object has no attribute 'PathName'
at Microsoft.Scripting.Interpreter.LightLambda.Run3[T0,T1,T2,TRet](T0 arg0, T1 arg1, T2 arg2)
at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
at IronPython.Compiler.Ast.DynamicGetMemberExpression.GetMemberInstruction.Run(InterpretedFrame frame)
at IronPython.Runtime.PythonProperty.__get__(CodeContext context, Object instance, Object owner)
at IronPython.Runtime.PythonProperty.TryGetValue(CodeContext context, Object instance, PythonType owner, Object& value)
at IronPython.Runtime.Types.GetMemberDelegates.SlotOnly(CallSite site, Object self, CodeContext context)
at IronPython.Compiler.PythonCallTargets.OriginalCallTarget3(PythonFunction function, Object arg0, Object arg1, Object arg2)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`6.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run6[T0,T1,T2,T3,T4,T5,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5)
at System.Dynamic.UpdateDelegates.UpdateAndExecute5[T0,T1,T2,T3,T4,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
at Microsoft.Scripting.Interpreter.DynamicInstruction`6.Run(InterpretedFrame frame)
at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2)
at Microsoft.Scripting.Interpreter.DynamicInstruction`4.Run(InterpretedFrame frame)
