Hi, i try to create "batch detached "for central files. But i have problem with “The model could not be saved” exception. I couldn’t find what cause the problem. Do you know how to go around this error? Here is my code:
from pyrevit import output
## def / class
## Pick folder with models (input)
models_folder = forms.pick_folder(title="Pick folder where the models, to be detached, are")
print(models_folder)
models_folder_detached = forms.pick_folder(title="Pick folder where you want to save detached models")
models_paths =[]
for root, dirs, files in os.walk(models_folder):
for revit_file in files:
if ".rvt" in revit_file:
models_paths.append(os.path.join(root, revit_file))
print(models_paths)
## Open doc options
open_options = OpenOptions()
open_options.DetachFromCentralOption = DetachFromCentralOption.DetachAndPreserveWorksets
open_options.AllowOpeningLocalByWrongUser = True
## Save as doc options
worksharing_options = WorksharingSaveAsOptions()
worksharing_options.SaveAsCentral = True
save_as_options = SaveAsOptions()
save_as_options.SetWorksharingOptions(worksharing_options)
save_as_options.MaximumBackups = 1
save_as_options.OverwriteExistingFile = True
for revit_model in models_paths:
print(revit_model)
revit_model_path = ModelPathUtils.ConvertUserVisiblePathToModelPath(revit_model)
doc_det = __revit__.Application.OpenDocumentFile(revit_model_path, open_options)
doc_det.SaveAs(models_folder_detached, save_as_options)
doc_det.Close(False)
print(e)
print(e)
Error:
Thank you for your help!
