Hi @Jean-Marc,
it’s been a while since i worked on my code and a collegae installed a newer version of revit:
My code includes a wpf window wich uses the wrapper.
In the older versions of pyrevit it seems to work fine but in the new version we start to get the error below:
Is this error related to the bugs mentioned in the release notes?
the error:
Big thanks in advance.
File "C:\Users\hans.deneve\AppData\Roaming\pyRevit\Extensions\BBpy.extension\BBpy.tab\Filters.panel\col1.Stack\Finishing.Pushbutton\script.py", line 18, in <module>
File "C:\Users\hans.deneve\AppData\Roaming\pyRevit\Extensions\BBpy.extension\lib\UI\Window.py", line 10, in <module>
IOError: System.IO.IOException: Could not add reference to assembly IronPython.Wpf
at IronPython.Runtime.ClrModule.AddReference(CodeContext context, String name)
at IronPython.Runtime.ClrModule.AddReference(CodeContext context, Object[] references)
at Microsoft.Scripting.Interpreter.ActionCallInstruction`2.Run(InterpretedFrame frame)
at IronPython.Compiler.Ast.CallExpression.Invoke1Instruction.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run1[T0,TRet](T0 arg0)
at IronPython.Runtime.PythonContext.InitializeModule(String fileName, ModuleContext moduleContext, ScriptCode scriptCode, ModuleOptions options)
at IronPython.Runtime.Importer.LoadModuleFromSource(CodeContext context, String name, String path)
at IronPython.Runtime.Importer.LoadFromDisk(CodeContext context, String name, String fullName, String str)
at IronPython.Runtime.Importer.ImportFromPathHook(CodeContext context, String name, String fullName, List path, Func`5 defaultLoader)
at IronPython.Runtime.Importer.ImportFromPath(CodeContext context, String name, String fullName, List path)
at IronPython.Runtime.Importer.ImportNestedModule(CodeContext context, PythonModule module, String[] parts, Int32 current, List path)
at IronPython.Runtime.Importer.ImportModuleFrom(CodeContext context, Object from, String[] parts, Int32 current)
at IronPython.Runtime.Importer.ImportModule(CodeContext context, Object globals, String modName, Boolean bottom, Int32 level)
at IronPython.Modules.Builtin.__import__(CodeContext context, String name, Object globals, Object locals, Object fromlist, Int32 level)
at IronPython.Runtime.Importer.ImportLightThrow(CodeContext context, String fullName, PythonTuple from, Int32 level)
