Coming along nicely… I thought I would have to step up to C#, but Python is more responsive than I thought it would be… This is kinda like Revit Lookup - but with bulk editing capability.
V1 of Rover is done.
Some bug fixes complete. Added pattern matching for bulk edits.
Ex: A-[Name]-Existing go add prefix and suffix to view names.
As always - read the help.
nice one, that’s a good tool to have. Afterall Revit projects are just a 3D Database.
I have something similar in mind to create but I didin’t think of stealing RevitLookup part
(until now)
One recommendation for UI:
I’d separate zones visually more. When everything is highlighted = nothing is important.
You can make darker gray text for trees and inspector so the main section gets more attention.
Just sharing my 2 cents
Thanks - good notes.
UI is getting big overhaul in v2.
It will do more than 1:1 parameters.
It will stack parameters with processing rules between each parameter to parameter pass.
That will let you make 1 ,2 or more parameters and merge them into something entirely different down the line.
And an option to set the trigger for each parameter set. Getting fancy.
That will indeed take a much better UI. Probably even some drag and drop
Also need to look at this as python and a C# version. Performance could get out of hand quickly. Might even need some parallel processing before the transactions.
Strike all that - I’m blathering about my wrong app. You were talking about Rover.
Whoops. Wrong app - those were notes on my data pusher. ( Now renamed Universal translator.)
A. New glasses show up later this week.
B. I need to stop trying to type on a phone.
Current production version got some cleanup. Those white scroll bars were offensive.
Started add more right click context menus. Tidied up the bottom alignment and left space for some new features. And yes - the center pane needs a slightly lighter grey - not gray.
I had prototyped a color glyph system for the categories, but that hasn’t made it in there yet.
