Revit Link Visibility
Hi everyone,
How can I copy the settings (visibility, halftone, underlay, display settings) of a linked file from one view to another? For example, I have two Revit models, A and B, and both of them have the same linked file, Link_Test (in a real project there could be many linked files). In model A, I’ve already created a view template and configured everything. I then transferred the view template from model A to model B, but for some reason all the linked files in model B are always turned on.
How can I preserve the link settings exactly as they are in model A?
I’ve read through Can i copy RVT Link Display setting by Revit API? - Revit - Dynamo, but maybe I didn’t use the SetLinkOverrides method correctly, so I still haven’t been able to make it work.
I think this is because settings for connections cannot be transferred through a view template to another model. This is logical, because the same linked model in different projects are actually different elements.
Settings can probably only be transferred between view templates within the same model.
But if you are transferring RevitLinkGraphicsSettings, then check the correctness of the specified Ids for the linked files.
