Good morning,
after updating to Revit 2025 and pyrevit, Revit does not start as long as the Pyrevit add-in is loaded. I have already reinstalled Revit and Pyrevit, but that didn’t help. There is no error, Revit hangs directly on startup and after clicking a few times it crashes with “no response”.
On other Computers I have no problem.
Does anyone have any ideas what else I can do?
Revit version: 2025.2
Pyrevit Version: 5.0.0.24325
Thank you!
Jean-Marc
(Jean-Marc Couffin)
December 6, 2024, 12:21pm
2
Try to run pyrevit env
from the command line and report the result of the command here
Hello Mr. Jean-Marc,
here are the informations:
C:\Windows\system32>pyrevit env
==> Attachments
==> Installed Extensions
configurator | Type: Unknown | Repo: “” | Installed: “C:\Revit\Revit_Config_52657669740d0a\Skripte\configurator.extension”
C:\Users\t2_froemgen\AppData\Roaming\pyRevit\Extensions
==> Extension Search Paths
==> Installed Revits
Autodesk Revit 2025 | Version: 25.0.2.419 | Build: 20240307_1300(x64) | Language: 1033 | Path: "C:\Program Files\Autodesk\Revit 2025"
==> Running Revit Instances
Error: Object reference not set to an instance of an object.
Run with “–debug” option to see debug messages
Thank you!
Jean-Marc
(Jean-Marc Couffin)
December 6, 2024, 9:23pm
4
Can you try the steps described here
Charline
(F)
December 10, 2024, 1:12pm
5
The second solution works for me, thank you very much for the fast support!
