Revit API for MultiLeader
Does Revit API support creating MultiLeader?
Yes.
I think you should do a research in Revit API docs before opening a new topic here.
Also, here in the forum there is multiple topics about tags.
Thank you for sharing the entire IndependentTag API, I’m still new to this, so the term threw me off at first, which I just figure it’s called “References”. I’ll be sure to think extra carefully before posting any new topics here. Thanks again :slight_smile:
If you are starting your journey as a pyrevit developer I strongly recommend starting here.
And do a python course, a little bit of data bases and POO (Orientated Object Programming)
Cheers. :waving_hand:
If this is helpful, maybe you can mark as solved :white_check_mark:
