Revit 2025 Install Issues
Clean install for PyRevit 5.3.1.25308_signed. versions 2022-2024 installed just fine. 2025 - does not show loading and does not appear in the ribbon. Ran from CMD pyrevit attached and got this:
==> Attachments
master | Product: “2026 First Customer Ship” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2025 First Customer Ship” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2024.3” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2023.1.8” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2022.1.7” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2021.1.9” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2020.2.9” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2019.2.6” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
master | Product: “2018.3.3 Security Fix” | Engine: DEFAULT (2712) | Path: “C:\Users\ricks\AppData\Roaming\pyRevit-Master” | AllUsers
Any suggestions as to how I proceed?
It is a simple fix. Add-in manager. Verify PyRevit is selected. reboot. All fixed.
