Hello all,
Just join the forum!
I have recently installed the latest pyRevit release but it does not load and I have the below issue.
any ideas?
Hello all,
it is not the last release but my Revit, I have uninstalled the last and install the previous I had working before(pyRevit_4.8.15.24089_admin_signed) but have the same issue. Any ideas how to fix it?
Try these steps:
Uninstall pyRevit
Delete C:\ProgramData and %AppData%\ pyRevit and pyrevit-master folders
Move all Revit addins to a temporary location. Usual addins locations include:
%AppData%\Autodesk\Revit\Addins
%AppData%\Autodesk\ApplicationPlugins
%ProgramData%\Autodesk\Revit\Addins
%ProgramData%\Autodesk\ApplicationPlugins
[Reboot computer]
Reinstall pyRevit
Started each version of Revit confirming pyRevit successfully compiled at startup.
Move all Revit addins that were moved in step 3 back to their original location.
You may want to add them one at a time and start a revit session everytime to figure out which ones are causing the issue.
