I’m having issues with creating Revised Sheet Sets, thoughts?
ERROR [pyrevit.revit.db.transaction] Error in Transaction Context. Rolling back changes. | <type ‘exceptions.Exception’>:In session views setting failed.
File “C:\Users\Ken.Koense\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Drawing Set.panel\Revision.pulldown\Create Revised Sheet Set.pushbutton\script.py”, line 20, in
File “C:\Users\Ken.Koense\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\revit\db\create.py”, line 302, in create_revision_sheetset
Exception: In session views setting failed.
Autodesk.Revit.Exceptions.InvalidOperationException: In session views setting failed.
