Resource Reference Key Not Found?
Hi. Before I begin, let me say I couldn’t find the “how to ask for help” post, so I hope I’m providing sufficient information.
I made some scripts leveraging pyRevit - first by simply modifying a native pyRevit script, then eventually creating a folder for my extension and telling pyRevit to include that folder path. So far, so good.
I moved my extension to %AppData%\pyRevit\Extensions (a first step toward eventually helping my coworkers install it on their machines). Most scripts still worked, but some generated the error “AttributeError: ‘module’ object has no attribute ‘ResourceReferenceKeyNotFoundException’”. So I moved my extension back to its original folder and pointed pyRevit back to that folder once again – but that error continued! (By the way, I had used this script many times earlier during this same day without any issue.)
Feeling lost, I turned to ChatGPT, whose advice led me to adding the following code to one of my scripts, right after the import clr section:
import System
from pyrevit import framework as _fw
if (hasattr(System, ‘Windows’)
and hasattr(System.Windows, ‘ResourceReferenceKeyNotFoundException’)
and not hasattr(_fw.wpf, ‘ResourceReferenceKeyNotFoundException’)):
_fw.wpf.ResourceReferenceKeyNotFoundException = System.Windows.ResourceReferenceKeyNotFoundException
This got that script working again (good) though I don’t fully understand why (bad). However, today I noticed a new problem: one of pyRevit’s own functions – Modify->Renumber – is now also generating this error.
At ChatGPT’s suggestion, I closed Revit and deleted the %APPDATA%\pyRevit folder, then restarted Revit but the problem remains. Here’s what I get:
File "C:\Users\j.hutchings\AppData\Roaming\pyRevit-Master\extensions\pyRevitTools.extension\pyRevit.tab\Modify.panel\edit2.stack\ReNumber.pushbutton\script.py", line 415, in <module>
File "C:\Users\j.hutchings\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\forms\__init__.py", line 720, in show
File "C:\Users\j.hutchings\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\forms\__init__.py", line 677, in __init__
AttributeError: 'module' object has no attribute 'ResourceReferenceKeyNotFoundException'
System.MissingMemberException: 'module' object has no attribute 'ResourceReferenceKeyNotFoundException'
at Microsoft.Scripting.Runtime.LightExceptions.ThrowException(LightException lightEx)
at Microsoft.Scripting.Runtime.LightExceptions.CheckAndThrow(Object value)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`2.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run7[T0,T1,T2,T3,T4,T5,T6,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`9.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run9[T0,T1,T2,T3,T4,T5,T6,T7,T8,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6, T7 arg7, T8 arg8)
at CallSite.Target(Closure, CallSite, CodeContext, Object, Object, Object, Object, Object, Object)
at IronPython.Runtime.Types.PythonType.FastTypeSite`5.CallTarget(CallSite site, CodeContext context, Object type, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
at Microsoft.Scripting.Interpreter.DynamicInstruction`8.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.DynamicInstruction`7.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run6[T0,T1,T2,T3,T4,T5,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5)
at System.Dynamic.UpdateDelegates.UpdateAndExecute5[T0,T1,T2,T3,T4,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
at Microsoft.Scripting.Interpreter.DynamicInstruction`6.Run(InterpretedFrame frame)
at IronPython.Compiler.PythonScriptCode.Run(Scope scope)
at Microsoft.Scripting.Hosting.CompiledCode.Execute(ScriptScope scope)
Revit:
25.4.41.14
20251111_1515(x64)
2025.4.4
pyRevit:
6.0.0.26032+2145
I would like to know a) how to solve this, and b) what did I do wrong to cause this to happen in the first place? Many thanks for any assistance :folded_hands:
[As something probably unrelated but strange, after running Revit for the first time after deleting %APPDATA%\pyRevit, every time I opened a file I got a pyRevit popup saying “Document Opened” followed by the document path; also there was a new panel in my interface with some kind of a pyRevit test button. After closing Revit and restarting it, both of these behaviours are gone … as mysteriously as they had arrived! I can only assume some kind of test/trace mode was running, perhaps due to a toggle that hadn’t yet been set during that first run of Revit?]
I would not move your extension into the main pyRevit extension. Keep your stuff in its own directory. This will avoid mixing up names from one module to another.
As far as deployment, if you have a reasonably robust network (non-VPN), I’d put your extension on the network and have everyone point at that directory. It makes developing and updating everyone instantaneous (almost). The only big disadvantage is for laptop users that disconnect from the network for out of office use. For those, you can install in the location of your choice locally.
Even with VPN, I’ve found iit works well.
Thanks for the reply, Aaron. For now deployment will have to wait, since I still have no idea why/how I managed to break something so that even a native pyRevit script throws an error. If I can’t do that then I certainly can’t get others to add my extension.
Try the latest wip installer. This is a bug from 6.0 or 6.0
