I’m trying to reference my library in the custom extension folder. But when run the code thru plugin button in Revit, error prompted and showed “ImportError: No module named lib”. Can anyone help with this? Thanks in advance.
You should reference to a file, not to a folder.
Create test_lib.py under lib folder. In test_lib.py create random class like
class Test_Class():
#some code in here
So basically in ur python scripts you use:
from test_lib import Test_Class
What @Tomasz said.
Pyrevit loads the lib directory as it was the site-package folder of a python environment, so you don’t have to specify it in the import statement.
You can omit the __init__.py file in the lib folder.
